Keyboard shortcut for 'Preview in Browser' in Mac OS X [subject edited by moderator]
Guest
Feb 24, 2012 Feb 24, 2012
Hi
I'm on Mac OS X 10.6.4 using DW CS5.5
I have the smaller (not numeric) apple keyboard.
My shortcut for preview in browser is alt F12, but when I try this I just go into my sound and volume controls.
(I have set up a primary - Sarari - and secondary - Chrome - browser for preview)
I have tried the Cmnd F12 for another browser, but same problem.
I tried changing the shortcut in Preferences, but with no luck.
Please could you suggest a solution.
I need to preview websites constantly and it is really tedious to have to keep using the top panel.
Thanks.
Clare
22.0K
New Here , Dec 30, 2014 Dec 30, 2014
On an apple keyboard, you just have to hold down the 'fn' key to access the functions. So the shortcut is really 'fn+opt+F12'
If you do that, then you don't have to change your system preferences. ('fn+delete' will give you backspace.)
In Preferences > Preview in Browser, be sure to set both the primary and secondary browsers.
For apple keyboard, primary will be 'fn+opt+F12' and secondary will be 'fn+cmd+F12'
Mar 01, 2012 Mar 01, 2012
Hi Clare
Exactly the same problem here.
Just taken delivery of my new iMac complete with latest Adobe suite.
Like you say reverting back to the long way 'round is a right pain.
That said, I was beginning to think it was my setup until I eventually found your post.
I have no solution just a token comment that might help coax a solution
from some clever bod out there.
Cheers
Chris
Guest
You can create your own shortcuts.
Edit < Keyboard Shortcuts
and use the wizard to create your own.
Hi
Thanks for the suggestion.
I've just had a quick look at the wizard and I'm
not sure it can be fune-tuned to give you the
Primary and Secondary browser preview options can it?
It only lists 'Preview in Browser' and 'Edit Browser List'
Besides there are existing shortcuts for these functions (Option F12 and Command F12).
There are many DW5.5 / Lion glitches, only I cannot find this particular one documented
anywhere.
Chris
Guest
No click the Edit menu button in the top left corner of DW. Then down towards the bottom of that list should be KeyBoard Shortcuts. Thats where you edit and add new shortcuts.
Guest
Mar 02, 2012 Mar 02, 2012
Hi
Thanks for your replies!
"click the Edit menu button in the top left corner of DW. Then down towards the bottom of that list should be KeyBoard Shortcuts. Thats where you edit and add new shortcuts."
* when I click edit in DW I don't get any K-shortcut option. (I only see it in preferences)
"Obviously your operating system has reserved alt or cmnd + F12 for other services.
So you need to assign another shortcut key combination that is not already being used by your system (some trial and error may be required)."
* I have tried changing shortcuts in preferences ... all trial and error, no solution and success!
* I do also do F5 sometimes, but don't always have browser open ...
However ... I tried something else (Chris) ... I went to DW 'service preferences' ... then 'keyboard' ... and clicked on 'Use all F1, F2 etc. keys as standard function keys' and that seems to have worked!
Although, who knows what else that will effect ... we see.
Clare
Mar 10, 2012 Mar 10, 2012
Hi Clare
Yep that works. Obviously all the F buttons no longer do what they did
but I suppose it depends on how often you would use those shortcuts anyway.
With F12 being the volume up shortcut it's no problem using the slider in the menu bar
once in a while. It's also interesting that when pressed in isolation F11 and F12 now perform
interesting screen wipes.
Thanks again
Regards
Chris
Mar 22, 2012 Mar 22, 2012
Helo all, had the smae problem did an web search and found the answer to this problem.
Here is the link: http://osxdaily.com/2010/05/12/switch-your-mac-function-keys-to-work-as-standard-function-keys/
Under the 'Keyboard' tab in "System Prefs' check the box that says' Use all F1, F2 keys as standard function keys..'.
Cheers,
Jason
Jul 04, 2014 Jul 04, 2014
Jason,Yes: check "Use all F1, F2 keys as standard function". Thank you: a simple solution to an issue that was giving me a headache:Cheers.
Working as expected now.
Yeah I found the shortcuts menu item (under 'Dreamweaver' on a mac)
But it doesn't give the option to add a shortcut to 'Preview in Browser'.
Or if it does, I haven't worked out how.
In the meantime I will probably revert to Nancy's methodology until
Adobe address the problem.
Regards
I preview often as well.  Keep browsers open.  Save your document in DW.  Switch to browser and hit refresh (F5).  Works with all open browsers.
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media  Specialists
http://alt-web.com/
http://twitter.com/altweb
Nancy O'Shea— Product User, Community Expert & Moderator
Alt-Web Design & Publishing ~ Web : Print : Graphics : Media
Sep 29, 2013 Sep 29, 2013
I followed these directions and it wanted me to make a copy set of the shortcuts, which I did.  I then changed the ctrl F12 to another keyboard combo.  Afterwards, I then tried to do a preview and the cursor was spinning like it was trying to do something, but no preview.  It tried and then quit trying.
Deciding that did not work, I went back in to edit shortcuts and reselected the standard installed set of shortcuts.  I was afraid of this...now the original ctrl F12 does not work even though it shows that is what is assigned to the preview.
I'd like to at least get back to what I had.  Is there anyway to fix his / reset to install values withut reinstalling the software??
Nevermind, I got it working. Sorry for the trouble.
Once I identified my primary and secondary browsers in preferences, I opened the keyboard shortcuts menu and selected 'Document editing' under the 'Commands:' options. Scroll down and you should have the options for setting shortcuts for Preview in Primary and Secondary Browser.
As long as you set the shortcut keys to not interfere with the default system keys, you can leave the standard set of function keys at the system default.
May 07, 2015 May 07, 2015
Best solution! lol
