how to acces a dynamic text field inside a movieclip
Mar 2, 2012 6:00 AM
This is probably easy stuff for most of you guys but have tried to have this working for the past hour and it's not working.
I basicly have made my own button which is a movieclip. Inside the movieclip on the normal/roll off state i've put a dynamic textfieldwith instance name "textbtn"
my button is supposed to span 2 frames on my mainstage, thought is need to say something different in each frame.
Sofar I have this inside the movieclip on Frame 1:
textbtn.text = MovieClip(parent).buttonText;
on my mainstage in frame1 I have:
back_btn.addEventListener(MouseEvent.MOUSE_OVER, buttonRollOver);
back_btn.addEventListener(MouseEvent.MOUSE_OUT, buttonRollOut);
back_btn.addEventListener(MouseEvent.CLICK, buttonClick);
function buttonRollOut(event:MouseEvent):void{
    back_btn.gotoAndStop("off");
function buttonRollOver(event:MouseEvent):void{
    back_btn.gotoAndStop("over");
function buttonClick(event:MouseEvent):void{
    back_btn.gotoAndStop("click");
    gotoAndStop("frontpage2");
var buttonText = "this is frame1";
on my mainstage in frame2 I have:
buttonText = "this is frame2";
  • kglad
    Jul 21, 2002
    Mar 2, 2012 6:08 AM   in reply to kimtrager
    you'll need to execute:
    each time you want to update your textfield's text property.
    Mar 2, 2012 10:44 AM   in reply to kimtrager
    I think you're unnecessarily complexifying things.
    One good practice is not to litter the timeline inside movieclips with code. When you want to go find some code to adjust something you may have to traverse movieclips several levels deep to get at the code in some frame. It becomes unweildly very quickly.
    If you want to use the timeline, I would register the event listeners and also set the text of the button from the root timeline. I also would not use "frame labels" as they're very antiquated although usable.
    To make your buttons I would make a movieclip (setting the base class of the clip to flash.display.Sprite for optimization) and include 3 layers. layer 1 background, layer 2 roll, layer 3 text. I don't see any "on" state mentioned in your code so I left that out. The roll or 'selected' and 'textfield' layers should have instance names so you can access them. For instance I'd name the selected state graphic to selected_mc and the TextField to text_txt.
    If your button was named as you said back_btn then the code would look like this, remembering that the event passes a target property:
    Sprite(back_btn.getChildByName('selected_mc')).visible = false; // make sure the initial selected state is invisible
        Sprite(Sprite(event.currentTarget).getChildByName('selected_mc')).visible = false;
        TextField(Sprite(event.currentTarget).getChildByName('text_txt')).text = 'roll off'; // change to the roll off text
        Sprite(Sprite(event.currentTarget).getChildByName('selected_mc')).visible = true;
        TextField(Sprite(event.currentTarget).getChildByName('text_txt')).text = 'roll on'; // change to the roll on text
        TextField(Sprite(event.currentTarget).getChildByName('text_txt')).text = 'selected text'; // change to the selected text
    TextField(back_btn.getChildByName('text_txt')).text = 'start text'; // change to the starting text of the button
    The display list returns DisplayObject and DisplayObjectContainer so you always need to wrap things with the 'type' they are to access them properly. That's why I have Sprite() and TextField() wrapped around specific things. Doing that gives you access to their settings.
    Mar 2, 2012 11:35 AM   in reply to kimtrager
    I'm not quite sure I follow but are you saying that you don't want the button to show up but it is? The roll is setting the visible property on the selected state so that will fire off every time you roll over it.
    If the buttons are not supposed to show you should just initially set the .visible property of the entire button to false to assure it won't show up. You should also set the mouseEnabled property to false (and perhaps useHandCursor to false) so the user can't click it until you desire them to.
    edit:
    Ah ok, you're welcome.
    Apr 7, 2012 4:45 PM   in reply to sinious
    Hi Sinious,
    similar challenge here...
    I have a dynamic text field which currently works fine on the stage.
    (see code below).
    When I covert this field to a symbol movie clip,
    I can't seem to find the correct AS3 code to pass the text into the movie clip.
    I tried this without success;
    dynamic test field name = a_field
    movie clip instance name = a_mc
    AS3 code:     _root(a_mc.a_field);
    below is the current code which works fine prior to converting the dynamic text field to a movie clip;
    CS5.5 Flash  AS3
         import flash.netURLLoader;
         var xmlData:XML = new XML();
         var the URL_ur:URLRequest = new URLRequest("fieldinput.xml");
         var loader_ur:URLLoader = new URLLoader(theURL_ur);
         loader_ur.addEventListener("complete", fileLoaded);
         function fileLoaded(e,Event):void
              xmlData = XML(loader_ur.data);
              a_field.text = xmlData.a_text;
    side note.... within these forums, is there a way to insert one's code rather than retyping?
    Thanks in advance for your time and guidance.
    D-
    Apr 9, 2012 1:25 PM   in reply to DaLe Zki
    How you keep your references is completely up to you. If you never made a reference to the textfield or the movieclip (as a class variable or directly in a timeline script or such) then you'll have trouble accessing it.
    This is AS2, it no longer works in as3: _root
    I presume you're doing this in a frame script. I also presume you put a_mc and a_field in a frame manually by dragging it out of the library and onto the timeline.
    First thing to do is make sure you have an instance name specified. You mtnioned you set up a_mc and a_field. Those need to be instance names and not the name of them in the library. Whatever you name them in the library is meaningless. Once you drag them into your timeline, click it and look at your properties panel. The first textbox is the instance name. Those must be set properly for this to work.
    Here, I just keep re-using this screenshot I made to point out instance name which has nothing to do with your project but you get the idea:
    http://files.ertp.com/temp/exfix.jpg
    Make absolutely sure you gave them names.
    Then you need to always "type cast" which is a pain in the *** but is necessary. So for example you added correct instance names. You can literally:
    TextField(a_mc.getChildByName('a_field')).text = XML(loader_ur.data).toString();
    Apr 14, 2012 3:10 PM   in reply to sinious
    Thanks for your help.
    I inserted your script within the "function" noted in Post #9... with a host of complier errors.
    While posting it out side the "function" with both complier & output errors.....
    Does the MovieClip " a_mc " have to be declared first?
    a_mc = new MovieClip();
    var a_mc:MovieClip;
    ..... I tried this with only further errors......
    The script in Post #9 works fine until I change the textfield to Dynamic...
    If there is more AS3 required I would welcome your ideas.....
    (all the code thus far is what is in Post #9 )
    At a loss....
    Thanks again
    D-
    Apr 16, 2012 9:06 AM   in reply to DaLe Zki
    If you do not put something on the timeline with the "Instance Name" (refer to graphic) as a_mc, then yes it will need to be created before you can use it. Otherwise no, you can directly use it if you put it on the timline. e.g. you clicked in a frame, clicked on the text tool, set it to dynamic text and had drawn a text box. Afterwards you named the text box instance something. You can then use that instance name directly in actionscript code.
    However you did say a_mc and referred to it as a movieclip. So if that movieclip contained a dynamic text field, you'd need to go in a_mc and make sure the textfield had an instance name as well.
    So lets say you have a movieclip on your timeline with the INSTANCE NAME of a_mc. Lets say inside that clip you had a textfield with the INSTANCE NAME of a_field. You could do this to dump the XML into it:
    function fileLoaded(e:Event):void
             TextField(a_mc.getChildByName('a_field')).text = e.target.data;
    And you can just paste code in here really, although sometimes it comes out as tables and other weird stuff. Most of us actualy use the "HTML" button in the upper right and add in something like <pre> or <blockquote> or other tags to help make the code easier to read.
    Do note the reason I put TextField() around the code above is because any time you request to get a child by its instance name (getChildByName()) it returns a generic "DisplayObject". It's really annoying that the method doesn't sense the original type of the object it returns and generically returns a "DisplayObject" but that is what it does. So by putting TextField() around it I "cast" it back into what I know it should be, a TextField class. Therefore the .text() method will be available. Just a side note...
    Apr 16, 2012 10:31 AM   in reply to sinious
    Sinious,
    First of all, I greatly appreciate all the details and theory behind how & why the code works.
    You coach the way I learn.. Thanks !!
    Yes, I do have a Movie clip on the timeline (instance; a_mc) and within it, a dynamic text field (instance: a_field).
    Before I test the script, I would welcome a bit of clarity;
    At the end of your script above, you reference e.target.data.
    With my current external text source the XML file (fieldinput.xml), will your script access this
    exteranal file or do I use loader_ur.data as noted in my original "function fileLoaded..." in post #9 ?
    Thanks again for your time and assistance.
    D-
    Apr 16, 2012 10:41 AM   in reply to DaLe Zki
    The function fileLoaded is called by your XML loader telling it that it successfully parsed the XML. Once that happens, all the data in the XML is included in the event, which has the variable name of 'e'. So e.target refers directly to the loader that loaded the XML in the first place. So it's exactly like saying loader_ur.data to say e.target.data. You don't really need to keep a reference to loader_ur because the data is sent in the event.
    This is typically why people use the e.target.data approach. You create a loader in the middle of a function. You know at the end of that functions life the variable is garbage collected. However until the listener fires off, it still exists. Once the listener fires off after successfully loading the document people don't typically have a global variable (like loader_ur) to reference at all. They just refer to e.target to access it. So they access the loaders XML using e.target.data. After that the loader is removed in the next garbage collection sweep. You never really needed to keep loader_ur around at all. It just takes up extra memory.
    Apr 16, 2012 10:58 AM   in reply to sinious
    Great.....
    again, this helps a lot with a thorough understanding.
    I look forward to testing the script this evening...
    Many thanks
    D-
    Apr 16, 2012 11:15 AM   in reply to DaLe Zki
    You're welcome and good luck
    Apr 16, 2012 11:33 AM   in reply to sinious
    I you have a moment, I have one other challenge I am working on.
    (see forum re: "FlashVars pass field text to SWF")
    In this forum, I have been working with some great folks teaching
    me how to interface a SWF (RMA) which has been loaded into a PDF.
    Here, I am using an Acrobat form field to interface
    with the "said" dynamic text field we've been working with above.
    The last piece of my challenge is to get my AS3 script written
    properly to receive the text data sent from the PDF.
    If you are aware of any examples of this (PDF to SWF:RMA) project
    both AcroJS and AS3 scripts I'd appreciate a link or two....
    Thanks again
    D-
    Apr 16, 2012 1:02 PM   in reply to DaLe Zki
    I think I already posted in that link (I don't have the URL to atm). I mentioned to show the PDF in a StageWebView instance and then it was made clear there was some acrobat scripting syntax that I wasn't familiar with. There were links mentioned that deconstruct PDFs and let you access things inside them but displaying a PDF and accessing data from it at the same time is another level of difficulty. Most APIs either just let you display the PDF or let you read its guts and reconstruct it. Reconstructing is what you appear to want so I'd go that route. It's a lot of work but it lets you convert an input from a PDF into an actionscript input that looks identical (when styled to do so) so you can access the data that way.
    Otherwise this is not at all someone new to actionscript should be approaching. It's not "easy".
    Apr 16, 2012 1:40 PM   in reply to sinious
    Agreed,
    A novice to AS3... it's been a steep learning curve.
    Joel G. is planning on developing some examples soon...
    he has been a great resource...
    Back to your Lesson.... the Script worked perfect.....Thank you..
    Planning ahead .... when you have a moment,
    would you please explain how to code the same FLA with Multiple Dynamic text fields(which have respective MovieClips) ?
    Further, how would the/my xml file / code change?
    With the current coding above, say I add:
    MovieClip instance:  b_mc ,  with a Dynamic text field instance:   b_field
    Thanks in advance... again.
    D-
    Apr 17, 2012 8:49 AM   in reply to DaLe Zki
    Reading the PDF and reconstructing it is no simple task, that's for sure. When I say reconstruct I mean literally reading all the contents on a particular page and rebuilding that in flash using what flash has. Text in TextFields, images in Loaders, etc etc. Then all that content needs to be position. Inputs will need to be TextFields with the .type property set to be an input. It's a ton of work.
    Perhaps you could utilize a PDF to SWF converter?
    Have a look at this article below to see some useful information on PDFs and Flash:
    http://va.lent.in/blog/tag/pdf2swf/
    Apr 18, 2012 3:00 PM   in reply to sinious
    Thank you Sinious,
    I appreciate the PDF / Flash reference link.
    Insightful tools...
    Thanks again for the script re: accessing a dynamic text within a MoiveClip.
    D-
    Apr 19, 2012 6:15 AM   in reply to DaLe Zki
    May 14, 2012 1:53 PM   in reply to sinious
    Hi Sinious,
    Some good news,
    I was able to contruct the Interfacing codes (AcroJS and AS3) to have a
    PDF form TextField interface with a SWF (RMA).
    The origianl script (above) works perfect with the assumption, the
    SWF's dynamic TextField was interfacing with a XML file.
    So with the SWF now interfacing with a PDF, will the AS3 code above still
    pass the dynamic TExtField into the MovieClip?
    My first few attampts have been unsuccessful.....
    D-
