venky_123
Can not resolve a multiname reference unambiguously- OSMF build from scratch
Mar 2, 2012 4:16 AM
Tags: #osmf
Hi
I am trying to build OSMF from scratch and I have been following the Building OSMF and OSMF based projects guide - http://osmf.org/dev/osmf/specpdfs/building-osmf.pdf
I've been doing everything by the guide but when I try to compile the project, which is the unmodified trunk from SVN, I get the following error (see below). I did a fair bit of googling but to no avail. Please Help me out!
This is my entire log on compilation-
E:\OSMF\OSMF SVN\trunk>ant
Buildfile: E:\OSMF\OSMF SVN\trunk\build.xml
all:
build:
compile.osmf:
clean-bin:
build:
   [delete] Deleting: E:\OSMF\OSMF SVN\trunk\framework\OSMF\OSMF-build-config.tm
p.xml
     [copy] Copying 1 file to E:\OSMF\OSMF SVN\trunk\framework\OSMF
    [compc] Loading configuration file E:\OSMF\OSMF SVN\trunk\framework\OSMF\OSM
F-build-config.tmp.xml
    [compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\M
anifestParser.as: Error: Can not resolve a multiname reference unambiguously. or
g.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\buildtools
\sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:Base 64Decoder)
) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\o
rg\osmf\utils\Base64Decoder.as) are available.
    [compc]
    [compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\B
ootstrapInfoParser.as: Error: Can not resolve a multiname reference unambiguousl
y. org.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\build
tools\sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses :Base64Dec
oder)) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\O
SMF\org\osmf\utils\Base64Decoder.as) are available.
    [compc]
ediaParser.as: Error: Can not resolve a multiname reference unambiguously. org.o
smf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\buildtools\sd
ks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:Base64D ecoder)) a
nd org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\
    [compc]
    [compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\D
RMAdditionalHeaderParser.as: Error: Can not resolve a multiname reference unambi
guously. org.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk
\buildtools\sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mC lasses:Bas
e64Decoder)) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\frame
work\OSMF\org\osmf\utils\Base64Decoder.as) are available.
    [compc]
    [compc]
g.osmf.elements.f4mClasses:DateUtil (from E:\OSMF\OSMF SVN\trunk\buildtools\sdks
\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:DateUtil) ) and org.
osmf.utils:DateUtil (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\utils\D
ateUtil.as) are available.
    [compc]
    [compc]
    [compc]
    [compc]
anifestParser.as(137): col: 26 Error: Access of undefined property DateUtil.
    [compc]
    [compc]                             manifest.startTime = DateUtil.parseW3CDT
F(root.nmsp::startTime.text());
    [compc]                                                  ^
    [compc]
anifestParser.as(680): col: 18 Error: Type was not found or was not a compile-ti
me constant: Base64Decoder.
    [compc]
    [compc]                                     var decoder:Base64Decoder = new
Base64Decoder();
    [compc]                                                 ^
    [compc]
anifestParser.as(680): col: 38 Error: Call to a possibly undefined method Base64
Decoder.
    [compc]
Base64Decoder();
    [compc]
    [compc]
ootstrapInfoParser.as(92): col: 17 Error: Type was not found or was not a compil
e-time constant: Base64Decoder.
    [compc]
    [compc]                             var decoder:Base64Decoder = new Base64De
coder();
    [compc]                                         ^
    [compc]
ootstrapInfoParser.as(92): col: 37 Error: Call to a possibly undefined method Ba
se64Decoder.
    [compc]
coder();
    [compc]                                                             ^
    [compc]
ediaParser.as(67): col: 16 Error: Type was not found or was not a compile-time c
    [compc]
    [compc]                     var decoder:Base64Decoder;
    [compc]                                 ^
    [compc]
ediaParser.as(147): col: 19 Error: Call to a possibly undefined method Base64Dec
oder.
    [compc]
    [compc]                             decoder = new Base64Decoder();
    [compc]                                           ^
    [compc]
ediaParser.as(154): col: 19 Error: Call to a possibly undefined method Base64Dec
oder.
    [compc]
    [compc]                                           ^
    [compc]
ediaParser.as(187): col: 19 Error: Call to a possibly undefined method Base64Dec
oder.
    [compc]
    [compc]                                           ^
    [compc]
RMAdditionalHeaderParser.as(91): col: 17 Error: Type was not found or was not a
compile-time constant: Base64Decoder.
    [compc]
coder();
    [compc]                                         ^
    [compc]
RMAdditionalHeaderParser.as(91): col: 37 Error: Call to a possibly undefined met
hod Base64Decoder.
    [compc]
coder();
    [compc]                                                             ^
    [compc]
BUILD FAILED
E:\OSMF\OSMF SVN\trunk\build.xml:15: The following error occurred while executin
g this line:
E:\OSMF\OSMF SVN\trunk\build.xml:22: The following error occurred while executin
g this line:
E:\OSMF\OSMF SVN\trunk\build.xml:53: The following error occurred while executin
g this line:
E:\OSMF\OSMF SVN\trunk\framework\OSMF\build.xml:14: The following error occurred
while executing this line:
E:\OSMF\OSMF SVN\trunk\buildtools\utils.xml:107: compc task failed
Total time: 56 seconds
    Mar 2, 2012 5:15 AM   in reply to venky_123
    I see a reference to
    E:\OSMF\OSMF SVN\trunk\buildtools\sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.ele ments.f4mClasses:Base 64Decoder)
    please delete the osmf.swc from the flsx sdk 4.5.1 libs - it's an older version of what you're trying to build.
    Mar 2, 2012 6:53 AM   in reply to venky_123
    Hi venky,
    please disregard the integration tests - you can remove them from the build scripts, unless you want to add your tests to these suites. Sometimes they refer to internal assets that we forgot to remove.
    S.
    Mar 6, 2012 2:32 AM   in reply to venky_123
    Netstreamswitchmanager has a timer  that trigger the checking of the rules
    checkRulesTimer.addEventListener(TimerEvent.TIMER, checkRules);
    Mar 7, 2012 2:53 AM   in reply to venky_123
    Switchingrulebase is the base class only; it's never used by itself. The actual rules overwrite the getNewIndex() function when they extend the class.
