I create a form that allows user to change the HTML page title. It works, but after the form is submitted with the new page title, the title does not change immediately. The user has to refresh the page or go to another page to see the changed title. Is there a way to completely refresh the page on form submit and immediately show the results (ie new title) to the user?
Could be that what you call the "new page" isn't the new page at all. The browser may be displaying a cached copy of the old page. It might help for you to add not just the title, but the following headers as well:
<cfheader name="Cache-Control" value="no-cache,no-store,must-revalidate">
<cfheader name="Pragma" value="no-cache">
Thanks. However, it doesn't seem to work. The title still does not refresh after the form with settings is submitted, but all the other settings like website footer do update with new values immediately.
Here is my current header:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
<link rel="stylesheet" type="text/css" href="/styles/stylesheet.css"/>
<title>
<cfoutput>#qSettings.websiteTitle#</cfoutput>
</title>
</head>
I created this example and, suprisingly it works:
<cfform>
<cfinput type="text" name="websiteTitle">
<cfinput type="submit" name="submit">
</cfform>
<cfif isDefined("form.submit")>
<cfset websiteTitle = form.websiteTitle>
<cfelse>
<cfset websiteTitle = "no_title">
</cfif>
<head>
<title>
<cfoutput>#websiteTitle#</cfoutput>
</title>
</head>
<body>
</body>
I cannot post my exact case example, as it is pulling data from the database...
Maybe the reason for this to work is that I put the form ABOVE the header...
Regarding:
The position of the form is irrelevent. All that matters is that you set the variable before you attempt to use it.
To move forward, I suggest starting with the page that works, and start adding bits from the page that doesn't work until you have completely re-assembled it. And remember, test early, test often, and test again.
Eleeist wrote:
I have finally got to the root of the problem - the sequence in which code is executed.
I have fixed this and now everything works just fine. Thanks everyone for help
Great. I'll just append what I ended up with, just in case it contains something you might want to use.
<cfelse>
</cfif>
<head>
<title>
</title>
</head>
<body>
<cfform>
<cfinput type="text" name="websiteTitle" required="yes" message="Supply the title">
</cfform>
</body>
