mdc1313
Content generation error. Failed to open the InDesign file.
Mar 2, 2012 11:09 AM
Hey all -
In importing an article to a folio, I just received this error:
"Content generation error.
Failed to open the InDesign file. Please confirm the file can be opened in InDesign."
The file is open right now in InDesign. I can close it and reopen it with no errors.
I've tried resaving the article to a new file. No help.
I tried creating a new folio and importing the article there. No help.
All links are good. It's a simple file with images, a scrolling pane, and some buttons that link to other articles.
Anyone else run into this problem? Any solutions?
    Jun 21, 2012 12:45 PM   in reply to mdc1313
    Im getting this error also....?
    Want to avoid inporting each artical on at a time. Need to import multiple articals at once.
    Thanks.
    Screen shot 2012-06-21 at 3.43.55 PM.pngScreen shot 2012-06-21 at 3.44.45 PM.png
    Jun 21, 2012 12:49 PM   in reply to SFS-DPS
    Dang server was conected....Anyone know whay I have to disconect from server to use folio builder?
    Jun 21, 2012 1:16 PM   in reply to SFS-DPS
    That would allow you to create a local folio but wouldn't explain the content generation error.
    What version of InDesign? What version the tools? If you're trying to create a folio, which folder are you browsing to?
    Bob
    Jun 21, 2012 1:21 PM   in reply to Bob Levine
    Using CS6, tool pack v2, Browsing to folio folder on desktop...as pictured...but figured out when Im connected to the inhouse server....builder errors. Disconect and its all good...Just wondering why that is?
    Jun 21, 2012 1:41 PM   in reply to SFS-DPS
    Do you have alternate layouts in those articles? Were those articles saved as CS6 files or CS5.5/5?
    Bob
    Jun 22, 2012 5:12 AM   in reply to Bob Levine
    Saved as CS6, No Alt. layout. Tool Pack v21. Again....disconnecting form the inhouse server seems to be the issue. Was the same issue in CS5. However each day when I login to my CPU im automatically logged in to our work server....If I don't disconnect before using the folio builder it errors out. The verbiage in the Error seems to be irrelevant.
    Pehaps it is a bug? or the server dosent like CPU to connect to the cloud while connected to the server for security?
    Nov 28, 2012 3:05 AM   in reply to SFS-DPS
    I had the exact same problem, you disconnect from the server and all good..
  • Lohrii Alo
    Mar 29, 2012
    Nov 28, 2012 3:16 AM   in reply to amywilloughby
    like Amy suggested above, if you are uploading articles from a network drive, move your files over to local machine HD and upload from there. data upload from a network drive is known to cause unpredictable errors
