InDesign CS5.5 Not Responding
Feb 10, 2012 11:18 AM
Five to ten times a day InDesign stops responding. It's usually when I open a document and then try to click into a text box. I get the beachball and it never recovers. When force quitting it says that Indesign is not responding. I have to restart my computer at that point and it works for a while then starts to do this again. I have neither the time nor patience to deal with this, it's making it very difficult to get work done.
I've found a few threads that are similar and tried the fixes recommended to no avail (the main one being getting rid of a certain asian text plugin). But I have yet to find a thread that shares my exact problem.
Any help would be very much appreciated.
-Rod
Branched to a new discussion.
    Feb 10, 2012 1:24 PM   in reply to MartzCreative11
    Per John Hawkinson:
    When it hangs, run Activity Monitor, select InDesign, and run Sample Process. You'll get a report. Upload it to http://pastebin.com/.
    Then, chose View > Send Signal: Abort (SIGABRT). You'll get a crash report. Upload that to http://pastebin.com, too.
    Post both URLs here, we'll tell you why it hung.
    Mar 2, 2012 2:02 PM   in reply to MartzCreative11
    I am having the same problem, and have uploaded the reports.
    Mar 2, 2012 2:15 PM   in reply to Tryingtodothis
    But you haven't put links to them here, so we still have no way to help you.
    Mar 2, 2012 2:24 PM   in reply to Peter Spier
    Mar 2, 2012 2:47 PM   in reply to MartzCreative11
    Sorry about that. The bad news is I'm not the guy who's good at interpreting these things. Both of you seem to have similar reports, and whatever it is is font related, but I can't tell you more than that.
    I wonder why John never popped in...
    Mar 2, 2012 2:53 PM   in reply to Peter Spier
    Thanks. I'll look at my fonts.
    Mar 2, 2012 3:04 PM   in reply to Tryingtodothis
    Are either of you packaging files that have linked ID files nested in them? Do you run Suitcase?
    Mar 2, 2012 3:11 PM   in reply to Peter Spier
    No nested ID files, no Suitcase.
    Am running font doctor now.
    Mar 2, 2012 3:55 PM   in reply to Peter Spier
    I've fixed the fonts, resaved the file, trashed preferences, restarted, run Disk Utility, and am still unable to complete the packaging process on the document.
    Mar 2, 2012 4:26 PM   in reply to MartzCreative11
    It seems more of the permission issue, check in the new user account with the administrator privilages and then check.
    Also , check moving the Prepress folder out on the desktop from the Plugins folder of Indesign.
    Mar 2, 2012 5:06 PM   in reply to Manish-Sharma
    Not sure what you mean by the "new user account with the administrator privileges" ?
    Where would I find that?
    Mar 2, 2012 5:45 PM   in reply to Tryingtodothis
    Create one as a test. If ID works when logged in with this new account, then there is something wrong with you original account, most likely permissions. Your options are to go through the old account and find what's worng or use the new account a n rebuild you preferences as you need them.
  • John Hawkinson
    Jun 25, 2009
    Mar 2, 2012 9:24 PM   in reply to Peter Spier
    Sorry, I missed this on the first go 'round, and this has been a fairly busy week for me. Finally catching up.
    As Peter suggested, this is definitely font related. Try Larry's suggestion because it is easier, but I doubt it will help.
    It appears that there is a problem of some sort with some font that you have. The hang takes place in the AdobeCoolType module, but we don't know what it is doing (or trying to do). Merely that it is stuck.
    The general answer is to remove all your non-system fonts and confirm the problem is gone, and then add the fonts in by halves until you find which one is triggering the problem.
    You might be able to narrow this down more easily if it only happens with certain InDesign documents (that contain certain fonts).
    Are either of you well-versed in the Terminal? I could give you some recipes to try if none of the above work, bt it'll be a pain in the neck.
    Oh, actually -- what happens if you package the document up (including fonts) and try it on another machine? Or is that not feasible (either because you cannot get it open for long neough to package it, or bceause you don't have another machine)?
    Mar 2, 2012 10:46 PM   in reply to John Hawkinson
    It packages when I don't include the fonts in the package. And it
    works when I convert it to CS4.
  • John Hawkinson
    Jun 25, 2009
    Mar 2, 2012 10:51 PM   in reply to Tryingtodothis
    Well, that's a pretty good bet that it's one of the fonts in your document, then. Try removing all of them except one and confirming that it still packages (with fonts).
    Mar 2, 2012 11:26 PM   in reply to John Hawkinson
    I've narrowed it down to one set of fonts.
    Thanks for your help!
  • John Hawkinson
    Jun 25, 2009
    Mar 2, 2012 11:38 PM   in reply to Tryingtodothis
    You're welcome.
    But of course, this behavior still isn't acceptable for InDesign in the face of problematic fonts. What can you tell us about the fonts?
    Mar 3, 2012 9:32 AM   in reply to John Hawkinson
    The FontDoctor report said "These Bitmap Font files appear to be incompatible with this OS. "
    Does this mean they are corrupt? I've been using them for years with no problem.
  • John Hawkinson
    Jun 25, 2009
    Mar 3, 2012 1:31 PM   in reply to Tryingtodothis
    The Font Doctor manual says:
    Bitmap Fonts
    Mac OS X does not support older bitmap fonts (usually from System 6 and earlier). FontDoctor, however, does
    support these older font formats and can update them for you.
    This matches my recollection. Typically an old font would ship with a bitmap ("screen font") and then a postscript font. Under System 6 (wow, brings back memories), MacOS would use the screen font on the scren and the postscript to print. But starting with System 7, the bitmap font was ignored and the postscript (Type 1) font would be used on the screen and in print as well.
    So as long as you have the Type 1 font, the bitmap should be superfluous.
    Whether the bitmaps are causing the problem or not is a seperate question... they shouldn't be, but who knows?
    Sep 19, 2012 6:19 PM   in reply to MartzCreative11
    Dec 12, 2012 6:40 AM   in reply to Peter Spier
    Sample Process: http://pastebin.com/XutHnMbh
    Crash Report: http://pastebin.com/1FVUBims
    Mac OSX 10.6.8 - thanks in advance!
    Dec 12, 2012 6:47 AM   in reply to scheckyboy
    Your crash is caused by some sort of problem in the Extensis font manager. What version are you running?
    Dec 12, 2012 7:43 AM   in reply to Peter Spier
    Howdy,
    I'm running Suitcase Fusion 3 ver 14.2.1 - have had quite a few problems with this in the past to be honest, rebuilding font vaults etc etc.
    Any help would be appreciated!
    Dec 12, 2012 7:57 AM   in reply to scheckyboy
    I'm pretty sure version 3 is just flat out not compatible with CS5.5 (and probably not CS5). You need to upgrade.
