LukeElChul
Bullets Only Shoot 1 way???
Mar 4, 2012 7:47 AM
Tags: #help #flash #frame #swf #dynamic #as2 #play #actionscript #game #movie #clip #2.0 #objects #movie_clip #dinamyc
this is in my bullet movie clip on the timeline.
_root.bulletArray.push(this)
speed=12
_root.shootable=false
_rotation=_root.Dip._rotation
onEnterFrame=function(bullet){
          if(_x>550){
                    removeMovieClip(this)
          }else if(_x<0){
          }else if(_y>400){
          }else if(_y<0){
          _x+=Math.cos(_rotation*Math.PI/180)*speed
this is on the main timeline.
bulletArray = new Array()
Bullets = 0;
function shoot(){
           var Bullet = attachMovie("Meteor", "Meteor"+Bullets, _level0.getNextHighestDepth(), {_x:Dip._x, _y:Dip._y});
This is the script in my character.
onClipEvent (load) {
          gravity = 12;
          walkSpeed = 3;
          maxJump = 15;
          scale = _xscale;
onClipEvent (enterFrame) {
          if (Key.isDown(Key.LEFT)) {
                    _xscale = -scale;
                    _x -= walkSpeed;
                    _root.Dip.Dip1.gotoAndStop(2)
          if (Key.isDown(Key.RIGHT)) {
                    _xscale = +scale;
                    _x += walkSpeed;
          if (air == true) {
                    _y += gravity;
                    state = 3;
          if (_root.floor.hitTest(_x, _y, true)) {
                    air = false;
          } else {
                    air = true;
          if (Key.isDown(Key.UP) && jump == true) {
                    _y -= jumpSpeed;
          if (air == false) {
                    jump = true;
                    jumpcount = 1;
                    jumpSpeed = 30;
          if (Key.isDown(Key.UP)) {
                    jumpcount += 1;
                    jump = false
if (Key.isDown(Key.SPACE)) {
                    _root.shoot()
          if (this._x>=550) {
                    this._x = 545;
          if (this._x<=10) {
                    this._x = 15;
It all works but when i turn around it still shoots the same way im sure its something simple but i just cant work it out.
  • kglad
    Jul 21, 2002
    Mar 4, 2012 8:02 AM   in reply to LukeElChul
    _root.Dip is determining the direction your bullets shoot.  what is that?
  • kglad
    Jul 21, 2002
    Mar 4, 2012 8:37 AM   in reply to LukeElChul
    then try:
    speed=12
    //_rotation=_root.Dip._rotation
              if(_x>550){
              }else if(_x<0){
              }else if(_y>400){
              }else if(_y<0){
    Bullets = 0;
    function shoot(){
    Bullet._rotation=Dip._rotation
              gravity = 12;
              walkSpeed = 3;
              maxJump = 15;
              scale = _xscale;
                        _xscale = -scale;
                        _x -= walkSpeed;
                        _xscale = +scale;
                        _x += walkSpeed;
              if (air == true) {
                        _y += gravity;
                        state = 3;
                        air = false;
              } else {
                        air = true;
                        _y -= jumpSpeed;
              if (air == false) {
                        jump = true;
                        jumpcount = 1;
                        jumpSpeed = 30;
                        jumpcount += 1;
                        jump = false
                        _root.shoot()
              if (this._x>=550) {
                        this._x = 545;
              if (this._x<=10) {
                        this._x = 15;
    Mar 4, 2012 1:08 PM   in reply to kglad
    Oh wow.. kglad ive had to work around that for a long time... im so bad at cosine and sine and angles.. wish I know that before, thank you so much man!
  • kglad
    Jul 21, 2002
    Mar 4, 2012 3:40 PM   in reply to prodigalmaster
    you're welcome.
    you should work on moving all code from objects to timelines (or classes).  but moving code from objects to timelines is a pretty easy transition and makes your code much easier to debug, maintain and extend.
  • kglad
    Jul 21, 2002
    Mar 6, 2012 7:09 AM   in reply to LukeElChul
    you're welcome.
    p.s. please mark correct/helpful responses.
