How to edit a photo in Lr4b1
Feb 28, 2012 6:44 PM
Tags: none (add) #pv2012Intro:
The purpose of this thread is for people to discuss tips, tricks, and difficulties editing PV2012 photos.
Please be courageous enough to post about what you love, what works, what doesn't, as well as what you don't like about PV2012.
Please keep personal comments to yourself. If you must uncork, consider discussing personal issues via PM, or create a new thread for venting them...
Reminder: Only you control which threads and which posts you read.
How to edit a photo, basically:
* exposure - squint and take a whack (don't worry too much about over-bright highlights or over dim shadows at this point. Some people have found that setting initial exposure by looking at the navigator or a thumbnail instead of the big picture helps to keep from getting misguided by extra-bright/dim areas).
* contrast - assess desired level of (midtone) contrasty-ness, and take a whack (don't worry too much about over-bright highlights or over dim shadows at this point).
* adjust highlights so they're not too bright (or dim)
* adjust shadows so they're not too dim (or bright).
optional:
* +whites to stretch exposure out a bit (stopping shy of the clip point, right at the clip point, or beyond the clip point, as desired).
* -whites to compress highest tones a bit (or a lot).
* -blacks to clip point to take full advantage of dynamic range, or beyond clip point to create some true blacks, or stop shy of clip point to keep darks from being too black.
* +blacks to eliminate true blacks, fill darkest tones, or compress shadows.
Assess midtones with the TAT tool (of the tone curve).
if midtones are too bright, drop exposure and take another pass at the rest...
if midtones are too dim, increase exposure and take another pass at the rest...
if midtones are OK, but it looks over contrasty, drop contrast and take another pass at the rest.
if midtones are OK, but it looks under contrasty, increase contrast and take another pass at the rest.
If tone is still not exactly what you want, use the tone curve.
If some areas are wonky use the locals...
Advanced editing topics:
(Note: If you want the opposite, then do the opposite)
How to increase intra-highlight contrast:
+whites -exposure -highlights +shadows
How to increase midtone contrast:
+contrast -highlights +shadows
(-vibrance and/or -saturation if this makes it too "colorful")
How to increase intra-shadow contrast:
-blacks +shadows
(if this makes midtones too bright, then -exposure...)
Note: @28/Feb/2012, my biggest use of the tone curve is for primping darkest blacks/shadows.
If all's well except mids are a tad bright:
-exposure +highlights +shadows
If all's well except mids are a tad dim:
+exposure -highlights -shadows
If -highlights is not recoverying enough highlights, or is creating too much highlight stratification, try -whites.
If deepest blacks are still too black, try +blacks.
Note: @28/Feb/2012, one of my biggest uses of locals is for primping highlights.
Bonus topics:
If image looks OK, but you want to punchify it, then follow the instructions for increasing highlight contrast, and/or midtone contrast, and/or intra-shadow contrast, and maybe toss in some clarity and adjust vib/sat.
And to unpunchify? - do the opposite...
Often (meaning not always by a long shot), optimal toning includes -highlights value of same magnitude as +shadows value. For normal photos, when fairly normal results are desired, it's often a good starting point.
If you want radically different toning than what you can do with the basics, then after getting image as close as possible using the basics, go crazy with the point curve...
Don't forget, if you are having a very hard time getting the look right, maybe you need a different camera calibration profile.
Overly contrasty and too intensely colored? - try neutral.
Underly contrasty and not well saturated? - try vivid or landscape.
Also the RGB channel curves can be a godsend.
Troubleshooting:
* Overbright highlights? If nothing will bring them down, and they're like bright dead-zones, wait for beta #2 - this should be fixed.
* Shadow halos? Clarity halos are mostly gone, but now we have a new kind of haloing - dunno if this will be fixed or not, but Eric is aware of it.
* If new clarity looks ugly, wait for beta #2 - hopefully this will be improved.
* If highlights are still flat, or you can't get all whites white, or you can't get an "unadulterated" highlight look, try finessing whites/exposure/highlights/tone-point-curve/locals. If still not acceptable, switch to PV2010 - this will not be fixed (problem is auto-highlight recovery).
* If blacks are not blacking the way you want, this can usually be remedied by finessing the tone-point-curve (and maybe some locals) - difficulty is due to auto-shadow recovery.
* If you are converting an existing photo, beware of locals. Locals from previous process versions do not always translate well to PV2012, especially if they include a brightness adjustment.
Finally:
You can not use the tone/point curve for spot tone adjustment - tone curve should be smooth or it will (usually) destroy at least one tonal range. Use locals for spot toning.
If you seem to need a complex shaped tone curve, you probably haven't got the basics right yet.
Lastly:
by beta#2 I mean next release.
