Including files/resources using the ADT command line
Feb 27, 2012 5:36 PM
Tags: #files #resources #adt #-c #-e
Hi all,
I'm trying to get file support into my ADT helper tool before I release an update.  I am still having problems.
According to the Adobe docs on the subject, the following commands can be used:
-C "path/to/new/working/directory" [files and folders to include]
-e [files and folders to include] [package directory to add these to]
The following example works fine for me:
// This changes the working directory to my audio resources folder, and then packages the file 'track.mp3' into the root folder of my application package.
-C "C:\\resources\audio" "track.mp3"
Hoiwever using -e option in any way generates an error:
// This copies the file 'sfx.mp3' from the current working directory to the application package subdirectory 'lib'
-e sfx.mp3 lib
This also causes an error:
// Change the working directory to resources/audio and then copy the file called 'sfx.mp3' to the 'lib' subfolder of the application package. Error.
-C "C:\\resources\audio" -e sfx.mp3 lib
The error in both cases is:
File does not exist: sfx.mp3
Any ideas how I can use the -e option?  Does the working directory not come in to it - do i always have to use an absolute path to my file?
Thanks in advance,
Peter
    Mar 4, 2012 3:16 PM   in reply to Pea
    Not sure if it will help in your situation, but I just include files by adding the filepath at the end of my adt command line (no -e or -c). Eg (included files or bolded):
    "C:\Program Files (x86)\Java\jre6\bin\java" -jar C:\Users\t.randall\Documents\AIRSDK\AIR_3.0\lib\adt.jar -package -target ipa-ad-hoc -storetype pkcs12 -keystore ..\..\Deployment\CareerBox.p12 -storepass pass -provisioning-profile ..\..\Deployment\CareerBox.mobileprovision ..\..\CareerBox.ipa CareerBox_iPhone-app.xml CareerBox_iPhone.swf AppIconsForPublish\Icon29x.png AppIconsForPublish\Icon57x.png AppIconsForPublish\Icon@2x.png AppIconsForPublish\Icon512x.png AppIconsForPublish\Icon48x.png AppIconsForPublish\Icon72x.png Default.png Default@2x.png Default-Landscape~ipad.png Data\Cards.xml Data\CareerCards.xml
    Mar 5, 2012 8:41 AM   in reply to timothyrandall
    It's a bit easier to stick all your files in a folder and read them out of it.. At the end of the adt command line (before any native extensions -extensionDir) is where you specify files to include. I typically make one folder and include that just by typing the name of it. The only PITA is yes, all those app icon and default startup screen filenames.
    May 29, 2012 9:29 AM   in reply to Pea
    I found this page useful in working out how to package entire folders: http://help.adobe.com/en_US/air/build/WS901d38e593cd1bac1e63e3d128cdca 935b-8000.html
    You don't have to use -e at all. In fact I think -e is just for individual files.
    May 29, 2012 9:35 AM   in reply to Pea
    Do not use 'Resources' folder. It's will not work on iOS. You can use 'Resource' but not 'Resources'
