I have been working with iPad publishing software quite a while now and have experienced Woodwing as well as DPS. I have come across an issue with DPS which I can't find a solution for. When creating web view content, I mean either normal websites or Html5 animations the loading times with DPS are to long and there is the issue of the spinning loading.gif.
Is there some way to speed up the loading time for everything which is loaded within the web view window? How would I for example speed up the time to load animations from Edge or from Hype?
From my point of view this is a crucial thing to be solved.
Also I know from working with Woodwing that they solved that issue and things regarding the loading time of web content/animations are running a lot smoother. ( and no I can't just use Woodwing I need to solve this with DPS )
Solutions welcome and info on when stuff like this will be solved as well.
Thank you,
Alex
I agree that this is a real issue.
I asked an Adobe rep about this in person several weeks ago -- somewhat vaguely. He suggested that if the web view/html stack uses javascript, that we should be careful to use the minimum amount of libraries. (They load fresh each time?)
I'm not sure that that's actually true, the project I was doing with html stacks was done by then and I didn't test the theory. But my sense was that the time lag was for rendering the page or view, not loading js libraries. Maybe someone from Adobe can explain what is actually happening during the "spinner time."
The HTML loading time is really bad right now.
And it crashes the viewer often when loading multiple Edge animations with all that jQuery libraries each time.
The other problem is the "fade in" time after the page laded taking away a few milliseconds, too.
In the videos about Liquid Layout and the new way of adding Edge Animations (somewhat like dropping them into indesign), the animation loaded instantly. Don't know how they did that.
But there might be a better experience in a future version of DPS/InDesign
—Johannes
I've specifically added this request to our work items for an upcoming release. I spoke with the engineers last week and I'm hopeful there's a targeted change we can make to improve this. The big challenge on our end is verifying we don't break existing publications when we improve this.
Neil
Neil, you like steaks? You love steaks. You like tacos? YOU LOVE TACOS. Tell us some info and steaks and tacos are coming your way. Just a month & day. Thats it.
Just to be clear, I am bribing you. For legal stuff later-- want to make it super clear. Bribes are happening here.
