provlima
Need to reduce a file display size from its native  58x42"  to 36x24"
Mar 5, 2012 7:26 AM
I have a file I would like to have professionally enlarged  to a 36" x  24" canvas print
The photo file when displayed in the PSE9  window shows the size of my file  to measure 58" by 42".
Is it possible to set the PSE display window to show that file in a scaled down  actual 36" by 24"displayed  image so I can see the approximate loss of detail in the finished canvas print I plan on having made.
Also I notice that the border measurements are no to scale.  How can I adjust the view so that when I view an actual 12" segment, the image will actually measure 12" with a ruler?
Thank you for your help!
    Mar 5, 2012 9:04 AM   in reply to provlima
    The sizes which you reference do not have the same aspect ratio. You plan to end up with a 3:2 ratio, and will have to crop the original to conform.
    Use the Zoom tool (Z) to accommodate your screen.
    Go to View>check rulers to open the rulers to confirm the measurements visually.
    The info palette is very helpful for this as well.
    You should check with your lab to be sure that the resolution of your picture file is sufficient to assure a good canvas print.
    Please post your progress.
    Mar 7, 2012 4:20 PM   in reply to provlima
    Mar 7, 2012 6:15 PM   in reply to hatstead
    hatstead,
    Thanks for the link -- his explanations make a lot of sense.
    Ken
    Mar 8, 2012 4:17 AM   in reply to photodrawken
    Glad to help.
