Evilia_77
Object layer visibility - Applescript
Mar 5, 2012 11:27 AM
I am trying to write a script to change the object layer visibility in my documents. I get an error -1708. Does anyone can help me please.
this is my script
tell application "Adobe InDesign CS5.5"
  activate
          if active book exists then
          else
                    set GetParentPath to ((choose file with prompt "Kies een Indesignbook:" of type "IDb5.5"))
  open GetParentPath
  delay 1
          end if
end tell
          tell active book
                    set fileList to full name of book contents
          end tell
  --general
          set CountryArray to {"BE", "FR", "NL", "EX", "DE", "NO"}
          set CountryID to choose from list CountryArray with prompt "Selecteer de juiste catalogus prijzen." OK button name "Update book" without multiple selections allowed
  --make all layers visible
          repeat with aFile in fileList
                    set theDoc to open aFile
                    set myDocument to active document
                    tell myDocument
                              set layers's visible to true
                              set var_linkcount to count of links
                              repeat with j from 1 to var_linkcount
                                        tell graphic layer options of parent of link j
                                                  try
                                                            set graphic layers's visible to true
                                                            if CountryID is false then return
                                                            set Country to characters 1 thru 2 of item 1 of CountryID as string
                                                            set ActiveLayerOption to (Country & " prices")
                                                            set DeactivateLayerOption to {}
                                                            repeat with x from 1 to count of CountryArray
        set i to item x of CountryArray as string
        if i is Country then
        else
        set thisLayer to (i & " prices")
        try
        set visible of graphic layer thisLayer to false
        end try
        end if
                                                            end repeat
                                                  end try
                                        end tell
                              end repeat
                    end tell
  close theDoc saving yes
          end repeat
          display dialog "Layers zijn aangepast"
end tell
    Mar 5, 2012 2:10 PM   in reply to Evilia_77
    Hoi Evilia,
    (continuing in English ;) I've had some problems in Javascript doing the same thing. It seems to me changing a layer of an image invalidates the original reference to that image, so you have to "refresh" any pointers to it. See my Javascript near the bottom of this post: http://indesignsecrets.com/forum/indesign-add-ons-scripts-scripting-an d-plug-ins/object-layer-options-scripting
