'AIR App' failed to install via iTune sync with Flash Builder 4.6
Dec 1, 2011 12:20 AM
Tags: #flash_builder #flex #iphone #ios #release #compile
Hi all,
After download and setup fresh installation of Flash Builder 4.6, I start to create a simple Mobile project and run it as Fast build configuration.
I got a IPA file, so I added it to iTune, plugged my iPad, and sync the app.
Surprisingly, after synchronization completed, iPad shows a pop up: 'App Name' failed to install. This also happen with iPod touch too.
I use:
  • Mac OS X Lion 10.7.2
  • latest XCode version.
  • iOS certification and provision file that can be used in prerelease version of 4.6 and 4.5.1
I have to tell you that I don't do anything special in my project, just a button, photo, and a list.
Could you help me solve this? it might be a bug or may happen to the other.
    Dec 1, 2011 12:48 AM   in reply to Teerasej Jiraphatchandej
    In order to get more relevant error messages, try to install the app using your desktop iTunes and then sync via USB cable to see what the iTunes desktop app error messages are.  Usually they will point you in the right direction.
    Dec 1, 2011 10:00 AM   in reply to Teerasej Jiraphatchandej
    If I remember correctly you need a new provision for each version of the application you intend on releasing.
    Mar 5, 2012 4:00 PM   in reply to Teerasej Jiraphatchandej
    Thankyou for the info about creating new certs. It's fixed the issue I was also having trying to debug on an iPad. Insanely annoying having an app just refuse to deploy with NO message, NO error, NO reason.
    Hurray for iOS.
    Creating apps for Android devices is so much more straightforward.
    Apr 6, 2012 9:23 AM   in reply to Teerasej Jiraphatchandej
    Tried your suggestion for recreating the cert and profile, but I'm still encountering the same error. No useful information, just a "failed to install" alert. Anyone else having this problem?
    Apr 28, 2012 8:03 AM   in reply to Brian Vaughn
    I had this problem working with Flash 5.5 building an iPhone app.
    Even though I was saving the ipa file with the same name, to use the same certificate, provisioning etc.
    I was saving it from newer versions of my fla file, filenameV3.fla, etc.
    When saved over my original fla file, filename.fla and published it from there it installed on the iPhone without the error.
    Don't know if this applies to your Flash Builder project.
    I also don't know if this is perminant fix or I just got lucky this time.
    Very frustrating.
    Aug 31, 2012 12:34 PM   in reply to simon.oconnor
    in xcode you can check the organizer window under the window menu, when u are installing the app it show debug messages under your device -> console option, there it say it has signature problems, hope that helps!
    Calculating status...
    Dec 16, 2012 10:06 PM   in reply to Teerasej Jiraphatchandej
    app.xml if you mension the package id
    Dec 25, 2012 1:26 PM   in reply to Flex_CRJ
    Hi friends!,
    I type from Brazil, I need help.
    Recreate new Certificate and Mobile Provision, but the Itunes show me error "failed to install"
    Thank's.
    contact skype marciofermino,
    Dec 28, 2012 2:02 PM   in reply to marciofermino
    Yes !!!!!!!!!!!! only create new certificate!
