I have to load compiled css (swf) inside an application, when I load it like;
1. styleManager.loadStyleDeclarations('/demo/test.swf') - Works
2. styleManager.loadStyleDeclarations('http://ec202.classicinformatics.com/demo/test.swf') - Not Works
[not a loadable content]
What I need it I have a server for storing all styles, themes etc that I want to use for all application on any server.
Premkant
Possibly it is a crossdomain.xml issue? Meaning there is security keeping swf files from being access between two domains.
And you need to set the securityDomain parameter on loadStyleDeclarations.
I have crossdomain.xml already on server thats why I can load all other assets, only problem with style.swf.
Here is error I am getting
VerifyError: Error #1014: Class mx.modules::ModuleBase could not be found.
at flash.display::MovieClip/nextFrame()
at mx.core::FlexModuleFactory/deferredNextFrame()
at mx.core::FlexModuleFactory/update()
at mx.core::FlexModuleFactory/moduleCompleteHandler()
Did you set the securityDomain parameter in loadStyleDeclarations?
Here is how I am loading
var dis:IEventDispatcher = styleManager.loadStyleDeclarations('http://ec202.classicinformatics.com/demo/test.swf',true,false,
ApplicationDomain.currentDomain,SecurityDomain.currentDomain);
dis.addEventListener(StyleEvent.COMPLETE,styleComplete);
dis.addEventListener(StyleEvent.ERROR,styleError);
dis.addEventListener(StyleEvent.PROGRESS,styleProgress);
That looks right. Does http://e202.classicinformatics.com/crossdomain.xml permit the domain you are running from?
Sounds like the SWF is not being built correctly. I would try to find out why ModuleBase is not in the SWF.
This is not problem of different server but whenever I do use absolute path either on same server or different server same error.
Way 1:
ApplicationDomain.currentDomain,SecurityDomain.cu rrentDomain);
Never works;
Way 2:
var dis:IEventDispatcher = styleManager.loadStyleDeclarations('/demo/test.swf',true,false,
Always work fine.
Note: test.swf working fine if I use like way 2 but not if use like way 1 no matter on same server or different server.
Thanks a ton
What matters is the pair of URLs for the app and the module. What app/module pairs work and don’t work?
