Jan Renette
"Black" in RGB versus CMYK colors
Mar 5, 2012 9:31 AM
More a question than a discussion.
Just started with ADOBE INDESIGN 5.5 and created a document of 160 pages in 30x30 com format to be printed with Blurb later on. My images are in sRGB (or ADOBE-RGB) where the color "Black" is defined as RGB 0-0-0 (and translated into C91 M79 Y62 K97 in InDesign).
As background for the image in full spread in InDesign, I use the swatch "Black", defined as C0 M0 Y0 K100. However, when I print the document for proof in PDF, the CMYK background is "grey" and the RGB image really black. What is the reason???
I went somewhat further in my test to find out the reason...When I open the PDF proof document in Adobe Photoshop 5.1 and I check the colors, the swatch Black C0M0Y0K100 (added InDesign)  has been translated into R34 G34 B33 / C75 M65 Y62 K82.
So I have two blacks, the C91 M79 Y62 K97 (R0 G0 B0) from the placed image,  and
                                     C75 M65 Y62 K82 (R34 G34 B33) from the background Swatch.
I changed one of the backgrounds in InDesign into RGB colors (RGB 0-0-0) and then everything is OK on the PDF output. Does this mean that for consistent "Black" in printed book pages, you have always to work either in RGB or in CMYK, not at all in both combination. And is this the same for text defined in CMYK??
Thanks for your help.
Jan RENETTE
http://j.renette.free.fr
  • Andrew Rodney
    Apr 16, 2009
    Mar 5, 2012 9:36 AM   in reply to Jan Renette
    Adobe treats process black (which is what you are getting with the CMYK conversion) versus Rich Black (for say type) where the later is always 100% K with zero CMY.
  • Andrew Rodney
    Apr 16, 2009
    Mar 5, 2012 3:05 PM   in reply to Jan Renette
    The question becomes, do you want black to be defined as 100% K only or using the process the profile describes for black? For type, you’d probably want 100% K only and that is what should happen in ID. But for an image, not necessarily the case. You’ll get black assuming the profile correctly defines the CMYK process (for process black).
    Mar 6, 2012 1:18 AM   in reply to Jan Renette
    Jan, you may proceed as follows.
    1) Ask the printer, which CMYK profile is most appropriate for his offset process.
    2) Most common in Europe is Iso Coated v2 (ECI).
    3) Choose this profile in Photoshop for CMYK and synchronize all programs by Bridge.
    4) Choose either sRGB or AdobeRGB as RGB-profile, but don't change it later for the
        same document.
    5) Optimize all RGB images and embed always the profile.
    6) Verify by View > Proof Setup (Iso Coated v2 (ECI) > Proof colors / Gamut Warning
       that the RGB image is printable without change of appearance.
       Eventually apply modifications (often a saturation reduction).
    7) Finally convert to CMYK and save as a new version.
    8) Editing in CMYK is a matter for experts. One can easily get too much ink
       (Total Ink Limit violation).
    9) Make the InDesign file. This does not have a global RGB or CMYK mode.
        Both types can coexist (opposed to Illustrator). Just this is the problem.
    10) Create a swatch for Rich Black in ID. That's the darkest printable black.
        Define in Photoshop R0G0B0 or L0a0b0 and read (for Iso Coated):
        C88M79Y64K93. Use these values for the swatch.
    11) Use the Rich Black Swatch for your background, if you like.
    12) Place your CMYK images.
    13) Type text by C0M0Y0K100 = K-only. Overprinting, unless the size is very large.
    14) Export as PDF/X1a. Colors unchanged. No profiles embedded. But Output Intent
    15) Check by Photoshop. Open as CMYK file (!!). Your Rich Black Swatch and all
       the other swatches in CMYK will have the defined values (the will not, if you open
       the file as RGB file). Verify by values in the Info Panel.
    16) Verify PDF/X1a compatibility by Acrobat Professional > Print Production > Preflight.
    There are here and there alternatives.
    About Rich Black:
    http://en.wikipedia.org/wiki/Rich_black
    Best regards --Gernot Hoffmann
    Mar 7, 2012 3:05 PM   in reply to Jan Renette
    You're printing with Blurb. That's a digital press. You HAVE to specify your background colors as CMYK process - percentages of Cyan, Magenta, Yellow and Black. Then you have to make sure that whatever your black background of your image is in cmyk is and use exactly the same build in Indesign.
    It looks like you've got white type, but if you did have black you never want what Andrew calls a "rich" black, because in the inevitable event of plate misregistration, your type would have color fringes from the cyan, magenta and yellow plates. Not pretty. Black type is virtually always spec'd as 100% K for that reason.
    But back to your problem. This is the reason you have to design projects like this in CMYK, no matter how many people tell you it can all be done in RGB. It can't, unless you know for sure that your blacks from your different design elements will end up with exactly the same cmyk build percentages. And you'd be surprised at how little deviation it takes to actually see it in print. Enough that you should even turn the dithering off in the convert to profile dialog, as that alone can cause a visible change.
    Mar 13, 2012 1:12 AM   in reply to Jan Renette
    Jan
    you're welcome. The percentages of the four inks depend on the profile,
    that's to say on the specific printing process. That's the reason for
    different 'mixtures'.
    Using exactly the same mixture as indicated by Photoshop for a profile
    with input L=0,a=0, b=0 (same result for R=0,G=0,B=0) would deliver a
    background black which matches exactly the darkest black in images
    nearby.
    Using for instance C=70, M=70, Y=0, K=100 would deliver a Rich Black
    as well, e.g. for a page background without special reference to images,
    here with a reduced amount of total ink coverage.
    By the way: adding ink Y can make the appearance lighter instead of
    darker.
    For offset printing we have (or had?) in Europe two standard profiles:
    Isocoated_v2_eci.icc
    Isocoated_v2_300_eci.icc
    These are the official filenames. The first profile has 320% or 330%
    total ink coverage, the second 300%.
