I am unable to download the 11.1.102.63 .MSI from http://www.adobe.com/products/flashplayer/fp_distribution3.html (both x64 and x86). I always recieve .62. I have cleared my cache and had the networking team clear the cache at the firewall level and this has not resolved the issue. Since US-CERT has sent out a notification on this based on Adobes security bulletin I need to get this done ASAP. Our security department is expecting this to be done as soon as possible. Does anyone have an alternate location to download the .MSI files from or have any idea when they will be availabe via the distribution site? I spent the better part of yesterday trying to get phone support from Adobe without any resolution.
All MSI installers at http://www.adobe.com/products/flashplayer/distribution3.html are now version 11.1.102.63
Adobe really dropped the ball here. You can get the exe installer at I havn't found the Msi isntaller for 11.1.102.63:
http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player_ax_32bit.exe
http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player_32bit.exe
http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player_ax_64bit.exe
http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player_64bit.exe
exe isntaller used -install for silent install.
Justin
It is not your cache - I also am unable to directly download the msi for 11.1.102.63. The msi installer is version 11.1.102.62.
Thank you "HelpMe...", your download link has the correct version. I was able to download and apply it to a system here and it updated correctly to version ...63.
I apologize that you guys ran into problems here. It appears we occasionally have issues with propagation of these files. I'll bring this up with the team again to see what we can do to smooth the process out.
Chris
It seems that the propagation issues are continuing. As of this morning, I am still only getting the 11.1.102.62 MSIs for both the 64- and 32-bit versions.
Spence,
Where are you lotcated?
Chris
Central Florida. Just tried again about 30 minutes ago and finally got the right versions. Thanks for your help!
