i2004shinc
multi-level roll over drop down menu problem!!
Mar 6, 2012 7:32 AM
i got the drop down menu to come down once rolled over but it cancels out all other actions meaning it cancels the functions of the rest of the menu none of my other buttons work now. how can i fix this?
each button has its own action ie:
onClipEvent (load) {
          num = 3;
on (rollOver) {
          if (_root.link != num) {
                              this.gotoAndPlay("over");
on (releaseOutside, rollOut) {
                    this.gotoAndPlay(_totalframes - _currentframe);
on (release) {
          if (_root.link != num and _root.animation == 1) {
                    _root.animation = 0;
                    _root.link_prev = _root.link;
                    _parent[("item" + _root.link)].gotoAndPlay("out");
                    _root.link = num;
                    _root.main.play();
then i created a button to frame the drop down movie and gave it the following action:
on(rollOver){
          PastorMenu.play();
when i try to put in the same as the main button it doesnt come down when rolled over. but done this way it will come down but none of the other main menu buttons work.
thanks in advance to anyone who can help
  • kglad
    Jul 21, 2002
    Mar 6, 2012 7:36 AM   in reply to i2004shinc
    use a loop and hitTest() for your submenu items.
  • kglad
    Jul 21, 2002
    Mar 6, 2012 8:15 AM   in reply to i2004shinc
    first, remove all code from objects.  it's difficult to debug and maintain and very difficult to help you.  so:
    var tl:MovieClip=this;
    yourbutton.onRelease=function(){
    tl.onMouseDown=checkSubmenuF;
    // the rest of you code
                        _root.link = num;
                        _root.main.play();
    function checkSubmenuF(){
    if(submenuitem.hitTest(_xmouse,_ymouse)){
    // do whatever
    } else {
    // do whatever else
    delete this.onMouseDown;
  • kglad
    Jul 21, 2002
    Mar 7, 2012 6:54 AM   in reply to i2004shinc
    you assign instance names to everything that needs to be referenced using actionscript and you apply your mouse handler methods to that instance name:
    yourbutton.num=3;
    yourbutton.onRollOver=function(){
    yourbutton.onReleaseOutside=yourbutton.onRollOut=function(){
  • kglad
    Jul 21, 2002
    Mar 7, 2012 9:13 AM   in reply to i2004shinc
    when you move code from a movieclip to a timeline, your paths to other objects will change.  you need to use the correct paths.
    you can always use the trace() function to find the path to anything in your app.
