Cameron.Jacobs
Flash Socket Policy File
Mar 5, 2012 2:40 PM
Tags: #flash #socket #policy #web_socket #websocket
Hello - just installed CF10 on Fedora 16 using Apache.  And am trying to run some websocket code, and it seems to work great as a websocket on Chrome and Firefox.  However on IE8 it does not seem to fail over to Flash.
I receive a console message:
[WebSocket] cannot connect to Web Socket server at ws://192.168.1.5:8585/cfusion/cfusion (SecurityError) make sure the server is running and Flash socket policy file is correctly placed
I have double checked that Start Flash Policy Server is enabled and I have disabled all firewalls on this machine.
As a fix attempt, I tried to copy "/opt/coldfusion10/cfusion/wwwroot/crossdomain.xml" to my site root "/data/site/".  But none of that has seemed to change anything.
Does anyone have any ideas for me to try or ran across this problem?  I haven't seen any complaints about WebSocket's Flash fallback, so I can only assume that it works, but it's just my installation that is having difficulty.
    Mar 6, 2012 1:22 AM   in reply to Cameron.Jacobs
    Hi Jacobs,
    Is this issue happening only on Fedora as we don't suooprt it and haven't tested on that. Can you please try it on any other supported OS.
    We have tested it on IE8 and it worked for us. Also can you enable debug for websocket and provide us the cfusion.log.(Mail me ksaini@adobe.com)
    To enable debugging:
    Go to: {cf_home}/lib/neo-websocket.xml  , , set logging level to debug and restart CF server
    After running the same testcase you will see debug entries on console.
    Kunal Saini
    Adobe ColdFusion Team
    Mar 30, 2012 10:53 PM   in reply to Cameron.Jacobs
    Yes we support Ubuntu and I will test on this config again. One more thing can you confirm Jacobs? Try to access websockets without Apache i.e access websocket with inbuilt webserver.
    Also are you running as root user as flash port 843 won't work otherwise?
    Kunal
    Apr 18, 2012 10:31 PM   in reply to Cameron.Jacobs
    Hi Jacobs,
    You can definately re-enable the internal port without re-instaling the CF. There are two cases:
    1. If you have configured Apache after installing CF(via wsconfig) then no need to do anything ,you can directly access port(8500/8501/) and access webroot.
    2. If you have configures Apache at the time of installation then, {cf_home}/runtime/conf/server.xml and make sure this code is uncommented:
    <Connector executor="tomcatThreadPool" maxThreads="50"
                   port="8500" protocol="org.apache.coyote.http11.Http11Protocol"
                   connectionTimeout="20000"
                   redirectPort="8445" />
    and restart CF.
    Also one more thing can you check if flash socket port 843 is enabled(netstat). BTW in the latest intermediate build we have changed this port to 1243.
    Kunal
    May 16, 2012 3:46 PM   in reply to Cameron.Jacobs
    I was banging my head against the wall with the same issue being described. My problem ended up being solved by opening the "Flash policy port" (can be found in neo-websockets.xml) in the firewall. My default port was 1243 (I also have 843 opened up as well). After opening up that all flash fallback support has been working in IE8 . Hope this helps someone else.
    May 17, 2012 10:54 AM   in reply to Cameron.Jacobs
    Hi Jacobs,
    This entry has been added after the intermediate build. Just try with the released CF10.  Just open the given port in firewall. Let me know if it helps.
    Kunal
