This is more of an as2 questions, but did not seem a section for that, so sorry if this is the wrong place.
I am working with a template that is built in as2, and when a button is clicked, a new browser window opens to a specified url and some info is passed to the php file. I already have this funcinality via as3 in another site, but my director wants it in this onld as2 template.
here is my as3 Code:
//Path to PHP File
var serverFile:String = "https://www.mypath.net/myphpfile.php";
//Instantiate a new URLVariables Object
var postVariables:URLVariables = new URLVariables();
//add custom variables
postVariables.GuestUserKey = 'myKeyInfo';
//Request the URL
var urlRequest:URLRequest = new URLRequest(serverFile);
//Assign data to URL
urlRequest.data = postVariables;
//Tell flash what method to send Data
urlRequest.method = URLRequestMethod.POST;
try
//Open new page and pass URL and Varaiables.
navigateToURL(urlRequest);
catch (event:Error)
trace(this + (event));
I need to achive this funcinality with as2 and here is what i have tried, but does not seem to work.
on (release) {
var myLoadVar:LoadVars = new LoadVars;
myLoadVar.GuestUserKey = 'myKeyInfo';
myVars.send("https://www.mypath.net/myphpfile.php", myLoadVar, 'POST');
also, I have no control over the php file
thanks.
this is the as1/as2 forum: http://forums.adobe.com/community/flash/flash_actionscript?view=discussions&start=0&numResults=50
use:
var sendLV:LoadVars=new LoadVars();
var receiveLV:LoadVars=new LoadVars();
receiveLV.onData=function(src){
// do whatever with src - at least, use it for debugging.
yourbutton.onRelease=function(){
sendLV.GuestUserKey='myKeyInfo';
sendLV.sendAndLoad("https://www.mypath.net/myphpfile.php", receiveLV, 'POST');
Kglad,
Thanks again for your help, the above solution was just about what I needed sans one line of code, since I needed to open a new window, and then send the GuestUserKey as a variable the following coded ended up working.
kglad wrote:
this is the as1/as2 forum: http://forums.adobe.com/community/flash/flash_actionscript?view=discus sions&start=0&numResults=50
use:
sendLV.send("https://www.mypath.net/myphpfile.php", "_blank", 'POST');
sendLV.sendAndLoad(
you're welcome.
