ous_test
Import failure
Mar 6, 2012 12:00 PM
Tags: #importing_video #importing_files
I have a set of pictures and videos in a directory. This imported without any problems in LR4Beta. Today I bought LR4, but when trying to import the pictures and videos the process stops and never finishes. I then quit LR4, but when trying to restart LR4 it crashes once, before I can open it again.
Any suggestions?
    Mar 6, 2012 12:26 PM   in reply to ous_test
    The Lr4 prefernce file may be corrupted. See guidance at http://forums.adobe.com/thread/358041?tstart=0 for details on where to find the file, relocate the file to Desktop or trash it, then restart Lr
    Mar 6, 2012 12:22 PM   in reply to ous_test
    Read Ian's post again, ous_test - he didn't mention corrupted images.
    Mar 6, 2012 1:12 PM   in reply to ous_test
    Lr may be having a problem with an individual file or a video. Try removing the video files to see if they are blocking the import. If this doesn't help then split the folder contents in two or select half the files for import. Repeat until you find the file or files that are cause the import to fail.
    Mar 6, 2012 1:21 PM   in reply to Ian Lyons
    I am too having problems with converting to LR4. I did have the beta installed. Had a 1000+ images in it. Installed LR4final today. LR4b catalogue converted ok. Tried to import LR3 catalogue with 55k+ images after that. Proces made a new copy etc. Import started. At 32.500 images the proces halted. Force quit LR. tried to reimport. New temp catalogue created. Toke some time to prepare catalogue for import. Eventuatlly the proces started. Seems that the old images/new changes had some problems: all images are imported again. Duplicates not noticed/indicated/etc. imported seems to be halted again at 32.896 files and no progress anymore. Any ideas???
    Mar 6, 2012 1:27 PM   in reply to camerahans
    Camerahans,
    Your issue is with Catalog import not file import. I suggest that you start a new thread, not confuse the issue in this one.
    Mar 6, 2012 1:33 PM   in reply to ous_test
    The number of files or even the mix shouldn't matter, but in previous versions there have been similar cases to yours. Could it be that ACDSee left a file (hidden or visble) in the original folder that's no longer present in the sucessful folders?
    Mar 15, 2012 4:24 AM   in reply to ous_test
    Perhaps I have a similar problem ....
    I try to import AVI files. They are all selected for import i.e. recognised by LR. When I attempt to do the import it hangs. When I cancel the import it tells me there were no images for import.
    This is from a folder consisting only of AVI files.
    I had the beta version and decided to upgrade. I have attempted this with the upgrade.
