I have it turned on in preferences.
I find the location of my photo using the map. I click add GPS coordinates and they are filled in to the metadata. However, I thought the program would also insert the name and address info of the location on the map, or at least try. City and country would be trivial.
It doesn't. What am I missing ?
Thank you.
I can't figure it out either.
I take a photo with empty location fields, drag it onto the map (a US suburban area), and all location fields remain empty. I tried saving the metadata to file (a jpg image), then tried rereading the data back in, but that didn't do the trick.
Are we missing a button, or extra step, or something?
Win 7 x64, reverse geocoding activated, internet connection up.
You'd think Adobe would have at least checked out their bullet items, wouldn't you? Possibly it is a problem with the Google map API, but I would like to believe that Adobe would have written the code so that LR4 would report there was a problem. Simple silence is not appreciated.
Very slight note drift...I created a thread where I asked just what Reverse geocoding is supposed to accomplish. I'm aware that it is supposed to use your lat/long in an attempt to determine address values, but just which specific fields in the metadata is reverse geocoding supposed to populate?
Does anyone have a pointer to information on just how reverse geocoding is supposed to work in LR4?
Just found this Terry White GPS video
http://www.youtube.com/watch?feature=player_embedded&v=h-9kSbLk26M
Looks as if it should happen automatically - but not for me! I must be missing something. Thought maybe the photos needed to be newly imported into non-beta LR4. I just imported a few new files and got not sublocatios and Terry did in his video. If you have sucess let me know. Bob
Another thought:
The reverse-geoencode-feature was disabled in the Beta. Maybe the uninstall of the Beta leaves something behind that prevents the feature from working correctly.
It would be interesting to know, if it works on a clean system without the previous Beta install.
But I have to admit, that many things I read in this board keep me away from downloading the Final and try it ... looks a little like that old "paying beta-tester"-thing.
How?
I think it would be usefull for everybody in this thread, to know, how you made it.
I just installed the trial, but can't get the reverse geoencoding working.
For those who are not willing to wait until we get a solution, here's a work around:
Use Jeffrey’s “GPS-Support” Geoencoding Plugin for Lightroom. It has a working bulk-reverse-geoencode-feature.
You can get it here: http://regex.info/blog/lightroom-goodies/gps
By the way another thought:
Could it depend on the image-format if that feature works or not?
I got it to work as it was also not working for me
Here is eaxctly what I did:
- Go to Catalog settings and under Metadata tab, disable both checkboxes for Reverse geocoding
- Close LR4
- Open LR4, drag some photos in Map somewhere to see that it does not geocode, which is correct in this state
- Go to Catalog settings and enable back both checkboxes for geocoding
- Drag some photos to map and voila, it's working
Yep...that worked for me. How odd.
I can see the gray location data. I have the same. But is there any shortcuts to enter these data permanently. If I click in one of the fields now it is blank. I would like a ctrl-... so set the location data with just a keypress. I can do it one field by one but that is to slow.
- Terje
c.frans w wrote:
I got it working !
Tried several times today, now it's OK
Frans
