adobe reader contained virus and was deleted
Mar 01, 2012 Mar 01, 2012
When tried to install adobe reader aih 10
I get a message Install "reader contained virus and was deleted". it is win 7 and a/virus was tempo. disabled.
I suspect that some program on my system is causing problem but which one?
Pls. assist.
19.8K
Mar 02, 2012 Mar 02, 2012
Nobody can know. check your system event log and the virus scanner's logs. And get a more relieble virus tool.
Mylenium
Mar 03, 2012 Mar 03, 2012
Download the full installer from http://get.adobe.com/reader/enterprise/
Thank you Pat,
It did not make any difference. After d/loading 51mb of it a massage popped
saying same thing A/Reader contain virus and was deleted.
What kind of antivirus software are you using?  Try to disable it during the download and install.
Also make sure you have the latest antivirus definitions installed; this should fix any false positives.
Mar 04, 2012 Mar 04, 2012
In my previous tread I did mention that anti virus "Kaspersky" that is on
my system has been disabled. Must be some other program that prevents it
being installed. I can d/load it ok but instalation is a problem. If it was
Kaspersky preventing it than it would be indicated so according to
Kaspersky support team.
Thank you
You might have disabled your anti-virus but yet there could be some services which may be running in the background and causing the issue.
You and turn off your startup items and then try installing it.
Adobe Employee ,
Mar 05, 2012 Mar 05, 2012
Manish's suggestion is great for additional details on how to run in a selective start up I would recommend reviewing Disable startup items, services | Windows.
Thank You,
I've disabled start up items and services I did not have and still has not
worked.
Upon restarting win.I did not have message that says the System Conf.
utility has changed the way Win. start up.
I've tried on numerous occasions. Still no good result.
Adobe Employee ,
Are you on a corporate network which might have a cached copy of the file on the proxy server?  Alernately is it possible you might have additional virus protection software installed such as Microsoft Security Essentials?
I'm private user running win 7 and there is not another a/virus on the
system.
Thank you Jeff
Adobe Employee ,
Have you tried a different web browser?  Perhaps you have a toolbar or add-on which is generating this behavior.  You might even try using a web browser which you have not utilized previously to help ensure there is no additional components installed.
I tried f/fox and d/loaded it but does not give you an option to install
it. + I found this " Adobe has identified some issues with the current
Reader download center. The engineering team is working to address
them. Here are temporary workarounds for these known issues". How true is
this?
Adobe Employee ,
Mar 06, 2012 Mar 06, 2012
I am sorry Ivosevci but I am unsure where you could run into that issue either.  Are you using the link provided by Pat Willener at  http://get.adobe.com/reader/enterprise/?
I tried this link under Windows 7 and there seemed to be no opportunity to receive an error message about the download center.  You simply select your operating system, language, and version.  Which of these options did you choose?
Prior to disabling your anti-virus did you try running a full scan on your system?  There are viruses/malware out there which can cause your web browsers to be redirected to other sites but have been designed to look the same to the user.
@ Ivosevci
You have tried safe boot , selective startup and also disbaled the anti-virus and still getting the error message.
The error "adobe reader contained virus and was deleted" can come when we have the any software which is detecting this installer file as the Virus and as you said the "Kapersky" is the only Anti-virus you have installed on the system.
Hence , the only option is that I can suggest is to either contact "Kapersky" support or uninstall the Anti-virus completely and then try installing the Adobe reader, If it get installed then you can re-install your anti-virus.
And also please follow the step suggested by Jeff.
I'm using the link Pat provided entering correct data.
I run a/virus scan no problem.
I guess the only thing that is left to uninstall Kaspersky and then try.
Thank you.
Even in the past when I had Adobe Reader installed it would not open pdf
files giving the same message, and from memory this was around the same
time when I installed Kaspersky I think. Prior to that I had AVG which I
uninstalled but there is still something left of it in foreign language and
I think it is Korean fonts that I can not get off.
Adobe Employee ,
Lets see if you are able to get Adobe Reader installed successfully once you have Kaspersky removed.  It may also be worthwhile to contact them as well to see if they are aware of any issues which might be causing your difficulties.
Mar 07, 2012 Mar 07, 2012
It is not Kaspersky that is causing problems,They have been contacted and
enabled Kaspersky to trust Adobe.Still don't know what it is?
Remove " Kaspersky" completely and then check
Mar 08, 2012 Mar 08, 2012
Kaspersky has been removed completely and did not make deference.
Hi ivosevci,
Click on Start-> type "run" in the search filed without the quotes.
Click on the "Run"program that shows in the search results.
In the Run dialog box, type "drivers" without the quotes.
In the window that opens, click and open the folder named "ëtc".
Look for a file named hosts. Double click on it and open it with notepad.
Please check what is listed below "127.0.0.1 localhost" in this file and post a screenshot or the contents here.
Thank You
Copyright (c) 1993-2009 Microsoft Corp.
  1. This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
  1. This file contains the mappings of IP addresses to host names. Each
  2. entry should be kept on an individual line. The IP address should
  3. be placed in the first column followed by the corresponding host name.
  4. The IP address and the host name should be separated by at least one
  5. space.
  1. Additionally, comments (such as these) may be inserted on individual
  2. lines or following the machine name denoted by a '#' symbol.
  1. For example:
  1. 102.54.94.97 rhino.acme.com # source server
  2. 38.25.63.10 x.acme.com # x client host
  3. localhost name resolution is handled within DNS itself.
  4. 127.0.0.1 localhost
  5. ::1 localhost
Try these steps:
1. Navigate to "My Computer" and click on the "Tools" option at the top of the screen. (press the alt key on your keyboard if you dont see the option).
2. Click on "Folder Options". Then click on the "View" tab.
3. Uncheck "Hide extensions for known file types". Click on Apply and then OK.
4. Navigate to the download link provided by Pat: http://get.adobe.com/reader/enterprise/.
5. Select your operating system and the version of Reader you want to download and click on the Download button.
6. When you see the pop up prompting you about the download file, select Save As and choose the Desktop as the save location.
7. Then in the Save As dialog box, under the "Save as Type" dropdown menu, select "All Files".
8. Rename the file extension in the File Name field from .exe to .txt.
9. Allow the file to download.
Please reply to this post if the download completes and I will provide the next steps to install the application.
In the dialog box under save as type "all files " can not change exe to txt
or change anything in it.
I run Win 7 pro.
Thank You
