transparent background headache
Mar 6, 2012 12:59 PM
I cant seem to start a new document with a transparent background, it displays a white background instead.
Simple enough solution i'm sure but I seem to be going round in circles to get an answer.
Very much a beginner.
    Mar 6, 2012 1:18 PM   in reply to gotroots2
    Hi.
    A new document will always have a backround. Create a new layer and you can delete the background.
    Lee
    Mar 6, 2012 1:23 PM   in reply to gotroots2
    If your creating a new document with File>New, choose Transparent under Background Contents.
    Mar 6, 2012 1:24 PM   in reply to gotroots2
    Below is the "New Document" window in CS3.
    Hope that helps.
    Mar 6, 2012 1:31 PM   in reply to RenéG
    Oops!
    Forgot about that.
    Lee
    Mar 6, 2012 1:46 PM   in reply to gotroots2
    Back where we started. Crtl+A will select all, then hit delete. The layer will be transparent. Or create a new layer and delete the white one.
    Lee
  • Noel Carboni
    Dec 23, 2006
    Mar 6, 2012 1:47 PM   in reply to gotroots2
    What do you have set in the Edit - Preferences - Transparency dialog for the Grid Colors?
    I ask, because you can instruct Photoshop not to put up the checkerboard pattern that's displayed by default.
    -Noel
    Mar 6, 2012 1:49 PM   in reply to gotroots2
    What happens if you go to Edit>Preferences>Performance and uncheck: Enable OpenGL Drawing?
    (restart photoshop and try making a new transparent document)
    Mar 6, 2012 2:42 PM   in reply to gotroots2
    Good.
    Noel had it right.
    Lee
