Not to retein text in the combobox widget
Mar 6, 2012 12:29 AM
Tags: #advanced #widget #combobox
Hello,
Just want to know any possiblity not to retein the text in the combobox widget? I am using Captivate 5.5. The current behavior is I select a value in the list of combobox on page A, and then I click a button to go to the next page B. When I am back to the page A, the value I just selected is there displayed in the combobox (as the selected value). I do not want to retein the text.
    Mar 6, 2012 2:44 AM   in reply to niuya_beijing
    Hello,
    Someone should extend this widget, so that one is able to change the value of the associated variable. I have tried by all means without such an extension but no way.  Extending is possible, but I'm not a coder. Jim Leichliter did extend some other widgets to allow this functionality: radiobutton, checkbox and TextArea. I blogged about those extended widgets.
    Lilybiri
    Mar 6, 2012 4:41 AM   in reply to niuya_beijing
    As of Cp 5.5, the combobox widget and dropdown widget both have memory leaks and should not be used in a production environment.  Extending these isn't a good option, but building one from the ground up would be a solution.
    Jim Leichliter
    Mar 6, 2012 4:51 AM   in reply to Jim Leichliter
    Thanks Jim, I remember you told me that some months ago and that was the reason I never published the third part of Widgets and Questions, where I would have explained dropdown, combobox and listbox widgets.
    BTW, has the listbox also memory leaks?
    Lieve
    Mar 6, 2012 4:53 AM   in reply to Lilybiri
    Listbox should be ok.
    Mar 6, 2012 11:17 PM   in reply to niuya_beijing
    Indeed, just like the other two widgets the Listbox widget should be modified to allow control over the variable showing up like Jim did for the other widgets. As I told, I have been trying with disabling/enabling hoping to reset the widgets but no way for the moment. About a better version, I recommend introducing a bug report about the memory leaks for the dropdown, combobox and a feature request to have all the widgets extended in the same way Jim realized for TextArea, radiobutton and checkboxes. I already did that...
    Lilybiri
    Mar 6, 2012 11:27 PM   in reply to niuya_beijing
    Oh no! There is no guarantee whatsoever that this bug will be fixed soon. All depends on the priority list of the developers. If you really need this, you should find a Flash developer that creates the widget for you, sorry for that.
    Lilybiri
    Mar 6, 2012 11:29 PM   in reply to niuya_beijing
    @Niuya.  It doesn't work like that.
    You submit a bug report (or in this case, it's more likely to be an Enhancement Request) and then Adobe will decide whether or not to do anything about it.
    One thing I feel fairly certain I can guarantee you...It WON'T be fixed by Adobe before the end of this month.  So if this component was essential to your current project, you need to have an alternate strategy that DOES NOT require Adobe to come to the party within the next few weeks or months.
    Mar 6, 2012 11:48 PM   in reply to niuya_beijing
    You seem to misunderstand who we are! Rod and me are just users like you, trying to help other users. We are NOT working for Adobe at all...
    Lilybiri
    Mar 7, 2012 2:36 AM   in reply to niuya_beijing
    In those blog posts, you'll find the direct link to Jim's (FREE) widgets:
    TextArea widget extended
    Extended widgets for ...
    If you are not yet fed up with me:
    Source list: Widgets and Custom Questions
    Tips for Widgets
    I'm planning a second part for the last post, about the Listbox and Vivid Text Caption widgets.
    Lilybiri
