Locked
How to load compiled style (style.swf) from other server.
Mar 05, 2012 Mar 05, 2012
      I have to load compiled css (swf) inside an application, when I load it  like;
1.  styleManager.loadStyleDeclarations('/demo/test.swf')  -   Works
2. styleManager.loadStyleDeclarations('http://ec202.classicinformatics.com/demo/test.swf')  -  Not Works
    [not a loadable content]
      What I need it I have a server for storing all styles, themes etc that I want to use for all application on any server.
Premkant
Developers
2.0K
Possibly it is a crossdomain.xml issue? Meaning there is security keeping swf files from being access between two domains.
Adobe Employee ,
And you need to set the securityDomain parameter on loadStyleDeclarations.
I have crossdomain.xml already on server thats why I can load all other assets, only problem with style.swf.
Here is error I am getting
VerifyError: Error #1014: Class mx.modules::ModuleBase could not be found.
          at flash.display::MovieClip/nextFrame()
          at mx.core::FlexModuleFactory/deferredNextFrame()
          at mx.core::FlexModuleFactory/update()
          at mx.core::FlexModuleFactory/moduleCompleteHandler()
Adobe Employee ,
Did you set the securityDomain parameter in loadStyleDeclarations?
Here is how I am loading
var dis:IEventDispatcher = styleManager.loadStyleDeclarations('http://ec202.classicinformatics.com/demo/test.swf',true,false,
                                        ApplicationDomain.currentDomain,SecurityDomain.currentDomain);
                                        dis.addEventListener(StyleEvent.COMPLETE,styleComplete);
                                        dis.addEventListener(StyleEvent.ERROR,styleError);
                                        dis.addEventListener(StyleEvent.PROGRESS,styleProgress);
Adobe Employee ,
Mar 06, 2012 Mar 06, 2012
That looks right. Does http://e202.classicinformatics.com/crossdomain.xml permit the domain you are running from?
Adobe Employee ,
Sounds like the SWF is not being built correctly. I would try to find out why ModuleBase is not in the SWF.
Mar 07, 2012 Mar 07, 2012
This is not problem of different server but whenever I do use absolute path either on same server or different server same error.
Way 1:
                                        ApplicationDomain.currentDomain,SecurityDomain.cu rrentDomain);
Never works;
Way 2:
var dis:IEventDispatcher = styleManager.loadStyleDeclarations('/demo/test.swf',true,false,
Always work fine.
Note: test.swf   working fine if I use like way 2 but not if use like way 1 no matter on same server or different server.
Thanks a ton
Adobe Employee ,
What matters is the pair of URLs for the app and the module. What app/module pairs work and don’t work?
