Mask in Flash
Feb 14, 2012 1:21 PM
when background image rolls thru earth I can see earth in and out of circle mask. It is supposed to look like earth moving with circle mask. You are only supposed to see the earth in the circle.
  • kglad
    Jul 21, 2002
    Feb 14, 2012 1:39 PM   in reply to jake hollaway
    then only mask earth, not the background.
  • kglad
    Jul 21, 2002
    Feb 14, 2012 6:28 PM   in reply to jake hollaway
    then mask it, too.
  • kglad
    Jul 21, 2002
    Mar 7, 2012 8:25 AM   in reply to jake hollaway
    1.  put each of your objects in its own layer.
    2.  order your layers the way you want.
    3.  mask those layers that you want masked.  contiguous layers can use the same mask, if that's what you want.  non-contiguous layers that need to use the same mask, require the use of more than 1 mask.
  • kglad
    Jul 21, 2002
    Mar 7, 2012 9:20 AM   in reply to jake hollaway
    your intro page you'll need to make yourself.  create a movieclip and display whatever you want seen in your intro.  (i have no idea what should be displayed in your intro.)
    then you'll need to add your intro movieclip to frame 1, add your skip intro button to the stage in frame 1 (along with your intro movieclip) and add a stop() to frame 1.  you'll then need to code your button to advance to wherever you want when the intro is skipped and when the intro is finished.
    edit:  i see your duplicate topic.  don't open two threads for the same topic.  end this thread and continue the skip intro discussion in your other thread.
