I spent today configuring and installing an instance of the AUSST2.0 software, following http://www.adobe.com/content/dam/Adobe/en/devnet/creativesuite/pdfs/Up dateServerSetupTool_TechNote.pdf
Here's where I am:
Via Firefox/IE I get the following when browsing to the Updaterfeed.xml:
XML Parsing Error: syntax error
Line Number 1, Column 1:
0001
Which I expect is ok... the server is sending the updaterfeed.xml. I can also download the updates directly through IE or Firefox. The corresponding entry in the IIS log is:
/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml - 80 - <MY IP ADDRESS> Mozilla/5.0+(Windows+NT+6.1;+WOW64;+rv:9.0.1)+Gecko/20100101+Firefox/ 9.0.1 304 0 0 196
When I attempt to do an update via Photoshop, I receive:
"The update server is not responding. The server might be offline temporarily, or the internet or firewall settings may be incorrect. Please try again later. Error Code: U41M1C213 "
This happens regardless of firewall status locally or on the server. Other communication to the server is fine.
the aamu.log on level 10 says:
2012-01-17T20:01:52: Entering slurpURL: (http://<SERVER IP>/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml) bytesPushed
2012-01-17T20:01:52: main download loop - waiting for network availability
2012-01-17T20:01:52: have network connection
2012-01-17T20:01:52: connected to: = http://<SERVER IP>/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml
2012-01-17T20:01:52: received status code from server
2012-01-17T20:01:52: slurpURL: (http://<SERVER IP>/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml) bytesPushed = 0
2012-01-17T20:01:52: CFU(Webfeed): dumping webfeed: C:\Users\<MY USERID>\AppData\Local\Adobe\AAMUpdater\1.0\Data\webfeed.xml
2012-01-17T20:01:52: CFU(Webfeed): ERROR: Invalid webfeed. Could not read webfeed sequence number.
2012-01-17T20:01:52: UCGetprogress : (B) Returning with value = 1
2012-01-17T20:01:52: UCGetprogress : Check for updates returning state for reffId =
2012-01-17T20:01:52: UCGetprogress : Check for updates returning state = 41
2012-01-17T20:01:52: UCGetprogress : Check for updates returning outError = 213
2012-01-17T20:01:52: UCGetprogress : Check for updates returning percent = 0
2012-01-17T20:01:52: UCGetprogress : Check for updates returning unique error code string = U41M1C213
2012-01-17T20:01:52: UCGetprogress : (D) Returning with value = 1
2012-01-17T20:01:52: Stepped into << UCGetUserPreferences >> call.
2012-01-17T20:01:52: Returning from << UCGetUserPreferences >> call with return value - = 1
The subsequent IIS Log entry for this is:
GET /AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml - 80 - <MY IP ADDRESS> AAM+Updater+1.0 406 0 0 19
I've added the <add name=”SSINC-xml” path=”*.xml” verb=”*” modules=”ServerSideIncludeModule” resourceType=”Unspecified”> to my web.config, per http://blogs.adobe.com/oobe/2010/09/enterprise-in-house-update-hosting -for-cs5.html
I continue to get the U41M1C213 error whilst updating. I can get the updates when I remove the AdobeUpdater.Overrides from C:\ProgramData\Adobe\AAMUpdater\1.0 (Win7)
Help?
**per run-around: http://forums.adobe.com/thread/951039 -> http://forums.adobe.com/thread/951039 -> here.
Hi MUIT2012
I too have had the exact same issue, but I thought I would follow up with my actual fix, as searching for "U41M1C213" through google constantly yielded this post, along with your others.
After digging through the blog replies on this thread > http://blogs.adobe.com/oobe/2010/09/enterprise-in-house-update-hosting -for-cs5.html < i did find the answer from both Christopher Kinard and Travis Henry which ultimately fixed this error.
I'll walk through the general setup
Hope this helps anybody that might be battling with this, as it does not appear to be very well documented.
