I spent today configuring and installing an instance of the AUSST2.0 software, following http://www.adobe.com/content/dam/Adobe/en/devnet/creativesuite/pdfs/Up dateServerSetupTool_TechNote.pdf
Here's where I am:
Via Firefox/IE I get the following when browsing to the Updaterfeed.xml:
XML Parsing Error: syntax error
Line Number 1, Column 1:
0001
Which I expect is ok... the server is sending the updaterfeed.xml. I can also download the updates directly through IE or Firefox. The corresponding entry in the IIS log is:
/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml - 80 - <MY IP ADDRESS> Mozilla/5.0+(Windows+NT+6.1;+WOW64;+rv:9.0.1)+Gecko/20100101+Firefox/ 9.0.1 304 0 0 196
When I attempt to do an update via Photoshop, I receive:
"The update server is not responding. The server might be offline temporarily, or the internet or firewall settings may be incorrect. Please try again later. Error Code: U41M1C213 "
This happens regardless of firewall status locally or on the server. Other communication to the server is fine.
the aamu.log on level 10 says:
2012-01-17T20:01:52: Entering slurpURL: (http://<SERVER IP>/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml) bytesPushed
2012-01-17T20:01:52: main download loop - waiting for network availability
2012-01-17T20:01:52: have network connection
2012-01-17T20:01:52: connected to: = http://<SERVER IP>/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml
2012-01-17T20:01:52: received status code from server
2012-01-17T20:01:52: slurpURL: (http://<SERVER IP>/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml) bytesPushed = 0
2012-01-17T20:01:52: CFU(Webfeed): dumping webfeed: C:\Users\<MY USERID>\AppData\Local\Adobe\AAMUpdater\1.0\Data\webfeed.xml
2012-01-17T20:01:52: CFU(Webfeed): ERROR: Invalid webfeed. Could not read webfeed sequence number.
2012-01-17T20:01:52: UCGetprogress : (B) Returning with value = 1
2012-01-17T20:01:52: UCGetprogress : Check for updates returning state for reffId =
2012-01-17T20:01:52: UCGetprogress : Check for updates returning state = 41
2012-01-17T20:01:52: UCGetprogress : Check for updates returning outError = 213
2012-01-17T20:01:52: UCGetprogress : Check for updates returning percent = 0
2012-01-17T20:01:52: UCGetprogress : Check for updates returning unique error code string = U41M1C213
2012-01-17T20:01:52: UCGetprogress : (D) Returning with value = 1
2012-01-17T20:01:52: Stepped into << UCGetUserPreferences >> call.
2012-01-17T20:01:52: Returning from << UCGetUserPreferences >> call with return value - = 1
The subsequent IIS Log entry for this is:
GET /AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml - 80 - <MY IP ADDRESS> AAM+Updater+1.0 406 0 0 19
I've added the <add name=”SSINC-xml” path=”*.xml” verb=”*” modules=”ServerSideIncludeModule” resourceType=”Unspecified”> to my web.config, per http://blogs.adobe.com/oobe/2010/09/enterprise-in-house-update-hosting -for-cs5.html
I continue to get the U41M1C213 error whilst updating. I can get the updates when I remove the AdobeUpdater.Overrides from C:\ProgramData\Adobe\AAMUpdater\1.0 (Win7)
Help?
MUIT2012 I would recommend posting your inquiry our Enterprise Deployment forum.
I will. Not sure how I missed it! Thanks Jeff.
*edit* cross-posted to: http://forums.adobe.com/thread/951039
and that wasn't a good spot for the question either... see http://forums.adobe.com/thread/951308
If you come here via google, you can try this for my solution.
http://forums.adobe.com/message/4252886#4252886
This was my fix for pretty much the exact error the op was having. No guarantees ![]()
