Lion OSX 10.7.3
Firefox 10.0.2 or Safari Version 5.1.3 (7534.53.10)
11.1.102.62 or 11.1.102.64
I keep looking on the site and I cannot find a prior version to 11.1.102.62; I can only find 11.1.102.64 and 10.1.102.64 nothing in between.
I am trying to troubleshoot.
Flash worked just fine on a computer with all of the same hardware a week ago, different computer that has been sent back so I cannot look at the software versions. I know that it was running the previous version of flash at least one release befor .62. All of the same issues occur with .64
Examples of issues:
(Below describes issues on Firefox, similar issues on Safari)
http://www.tonypa.pri.ee/blockarelli.html
It says "WELCOME 0123456789" at the top and whe you click on the game to play it you cannot do anything it just gives a dotted outline to the game.
http://www.tonypa.pri.ee/cobacoli.html
If you play level one and finish level one then starts over, if you finish level one agian it does nothing the screen does not change.
On stage select to play menu all levels and level score show as "88" (should be 1, 2, 3, etc. and then no score until played)
Simiarly to cobacoli
http://armorgames.com/play/11711/the-adventures-of-dear-explorer
It loads to main screen and all menu buttons show as "#Type1#" Should be something like Play, continue, settings, etc.
http://www.tonypa.pri.ee/taberinos.html
Once you finish the game the highscore list never comes up, the game just ends; the game does not restart.
The same happens here http://www.tonypa.pri.ee/turnellio.html
http://www.kongregate.com/games/mofunzone/zombie-exterminator
It just plays the mofunzone intro over and over again
Hulu videos have a decent amount of blank time before loading the ad. They do have a problem continuing to play when skipping around; I often have to click a couple different spots in the track before it starts playing again.
If you load this game the Armor logo plays, then the alillm.com plays then the game is just black
armorgames.com/play/11758/hazmat
Youtube videos on youtube seem to play fine on this computer. Everything to do with flash .62 works well on my other machine running snow leopard.
fully uninstalling and then reinstalling worked. http://forums.adobe.com/thread/928315
I am wondering what went wrong the first time. It was not completely broken, but many in many instances it was not working properly.
You can find previous releases of the Player here:
Where do I find previous versions of Flash Player?
Chris
As I already stated "I can only find 11.1.102.64 and 10.1.102.64 nothing in between." I need the earlier version of 11; I had it on my other computer and it worked just fine, now I cannot find it and all I can do is use the current ones which do not work.
Did you scroll down on the archive page that was linked in the FAQ?
I see the following releases listed:
Ok, I looked at and downloaded "(Released 11/10/2011) Flash Player 11.1.102.55 (174 MB)" yesterday, but I do not know what to do with it. I have a mac, will it even work?
After unzipping the file, you should be left with a folder of the same name. Go into it and then into the fp_11.1.102.55_archive\11_1r102_55_64bit folders. Inside there, find the file named "flashplayer11_1r102_55_mac.dmg" and double click that to mount the dmg. From there you should be able to install Flash Player like you normally would.
Well, flash is still not work properly, so I am going to say it is a different issue. This is dissapointing. I am going to try factory default and see what happens, it is possible the OS update was not a good one.
Thanks for the information, I hope it helps other people as well.
Glad you got it worked out!
Chris
