Hi all,
I have some video that was shot with a cell phone set on a table on its side. The result is all of the subjects are off 90 degrees. I know this isn't close to the correct way to shoot video, but it was given to me and I want to make the best of it.
I am able to rotate 90 degrees clockwise in PrE. Then I created a test output file, an AVI>DV-NTSC-Standard, and the output has black bars on both sides. I'm sure I'll have to live with that. However, the audio is out of sync, too. My goal is to create something that will be played on a Windows computer projected on a screen.
Can somebody suggest the best project and output settings? Here is what MediaInfo told me about the source files, which are .3gp files.
General
Complete name : C:\Users\....\VIDEO0051.3gp
Format : MPEG-4
Format profile : 3GPP Media Release 4
Codec ID : 3gp4
File size : 141 MiB
Duration : 6mn 30s
Overall bit rate : 3 029 Kbps
Video
Format : MPEG-4 Visual
Format profile : Simple@L6
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 6mn 29s
Bit rate mode : Constant
Bit rate : 3 000 Kbps
Nominal bit rate : 256 Kbps
Width : 800 pixels
Height : 480 pixels
Display aspect ratio : 1.667
Frame rate mode : Variable
Frame rate : 23.900 fps
Minimum frame rate : 1.996 fps
Maximum frame rate : 473.684 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.327
Stream size : 139 MiB (99%)
Title : VideoHandle
Language : English
Audio
Format : AMR
Format/Info : Adaptive Multi-Rate
Format profile : Narrow band
Codec ID : samr
Duration : 6mn 30s
Bit rate : 12.8 Kbps
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 13 bits
Stream size : 609 KiB (0%)
Title : SoundHandle
Writing library :
Language : English
For each Clip, go to Effects Tab, and with the Clip Selected, choose Edit Effects.
There you will see the Fixed Effects, Motion, Opacity and Rotation. Choose Rotation, and then just adjust as needed.
Note: you will then end up with portrait orientation, in a horizontal Video Frame, so will likely want to use Motion>Scale, and possibly Motion>Position to fill the Frame, or leave the black bars.
Good luck,
Hunt
It's going to be a challenge because your video source isn't a good fit for Premiere Elements AND it's sideways. But here's probably your best chance.
First, change your video clips' suffixes from AVI to MP4. That will make it less confusing for the program.
Then start a new project and select, for your project settings, the Flip Mino standard definition preset.
Import your video into the project and rotate it. Then press Enter to render your timeline.
Try outputting a test video using Share/Computer/MOV at its default settings and then play the results in Quicktime Player.
Hi Steve,
Sorry to be confusing, but the source clips are actually .3gp extensions.
I used the Flip Mino and Ultra 29_97p for the present, and output it using Computer > QuickTime > NTSC DV.
The output file size was 10 times as large as the source! Like I expected, the video and audio aren't synced up. Thanks for the help, but it appears this is impossible to work with.
I converted the only 3GP file I found on my computer to DV using Aimersoft Video Converter Pro. It converted well, video and sound (blurred but the original is 176x144 and I blew it up to DV 720x576.
Generally I find that Aimersoft Video Converter Pro handles just about anything I throw at it. They have a free trial that will let you see if it converts your file OK.
Cheers,
Neale
Insanity is hereditary, you get it from your children
Cool tip, Bill. I didn't know about Paste Attributes. Is that something new in 10?
Bill Hunt wrote:
Note: if you have multiple Clips that need Rotation, just adjust the first Clip, as is needed, and then Rt-click on that Clip, choosing Copy. Next, Select all other such Clips, Rt-click on them, and choose Paste Attributes to Rotate them too.
Good luck,
Hunt
