HI, WHen I put a basic transition on my timeline the picture goes pixelated. Before the transition is added, the picture is fine. This could be with any of the transitions that come with premiere...
Please see screen grab, and this is with the 'push' transition that comes with Premiere.
sequence settings
meta data of footage
Hi Jim and Ann. I did a test on a normal Adobe timeline and the results were similar, however when I took a screenshot from the premiere timeline of the same exported clip the result was this...
WHen I took a screenshot from a blackmagic timeline the result was this..
there seems to be more pixelation in the blackmagic timeline than there is in the Premiere timeline when taking a screenshot of the same mpeg clip. Strange isn't it?
here are my export and sequence settings...
I did two different export setttings both which had the same result.
Try a preset first before tweaking all kinds of parameters, unless you know what you are doing.
Set encoder quality to 4.
Your bitrate is not set to default.
2,8 - 5 - 7, try that.
Uncheck Render at Max bit depth.
Max bitdepth and render quality is only for preview in the sequence settings, might as well uncheck.
Hi Glenn, Sorry it's taken so long to get back to you. I've had the flu! I want to upload this video and want to know to make a smaller size, would I just tick the 'match sequence settings box' to give you the same file I'm working with. If not, how else will I give you a shorter clip of what I'm using. The clip I'm using is 1 hour long and around 11GB big.
Just take your camera and use the same settings you shot with before and take some test shots. See if it is still there or if it is just with the footage you have.
As a test create some color mattes and test the transitions to see if it has nothing to do with the footage and maybe its your sytem.
GLenn
Message was edited by: Powered by Design
Hey GLenn,
here is the link to my file... http://www.mediafire.com/?62haeiwyb3cth09
How do I test the mattes?
Hi GLenn,
I know I definitely tried with those settings that you have above. I thought it would be easier if I included a link to this thread in another discussion so you could see my computer specs. Is that ok?
http://forums.adobe.com/message/4272508#4272508
The funny thing though is that I get the same result on another computer.
After reading your other post I see you have a nice system.
To bad your builder wasnt Eric from ADK
I see Harm said to check your temps under normal and load. Speccy works good to see those temps.
I also fear that PSU is to small for your setup.
Have you gone to Nvidia and gotten the latest drivers for your Quadro 4000 ?
Show a screen grab of the temps with Speccy before and while rendering please.
GLenn
At this time I dont know what else might be giving you problems.
At least if it was doing the same thing on my system then we would know it was repeatable.
Since im getting good results I fear its something to do with your system.
Maybe those tests will tell if you system is getting to hot.
Mabye some with a better hardware understanding can chime in.
Glenn
