CFC URL variable
Mar 8, 2012 12:36 PM
I am having trouble with a URL varailble.  Does anyone know how to send a URL variable to the query in a CFC.  Here is what I have so far and it does not work. Thanks.
CFC:
<cffunction name="pagevideo" access="public" returntype="query">
  <cfset var pagevideo="">
  <cfif not IsDefined("URL.VideoID")>
    <cflocation url="page.cfm?videoID=486">
  <cfelse>
    <cfquery name="pagevideo" datasource="videos">
          SELECT video_path, ID, Video_Name,
    FROM Video
    WHERE ID = #URL.VideoID#
          </cfquery>
  </cfif>
  <cfreturn aged240video>
</cffunction>
CFM page:
<cfset myObj = createObject("component","cfc.page") />
<cfset queryObj = myObj.pagevideo()>
  <h2 >Page Header</h2>
<cfoutput><h2 >#queryObj.Video_Name#</h2></cfoutput>
    Mar 8, 2012 1:00 PM   in reply to TheScarecrow
    What is the error message, if any, you receive.  I also that the variable aged240video in your cfreturn is not defined.
    Try <cfreturn pagevideo> instead.
    You should also omit the line <cfset var pagevideo="">.
    You should also use CFQUERYPARAM in your query when passing in URL.VideoID.
    Mar 8, 2012 1:14 PM   in reply to TheScarecrow
    It appears that you have an extra comma after Video_Name in your query.  I suspect that this is causing the error.
    The CFQUERYPARAM tag is used to bind parameters to your SQL statements.  Use of bound parameters is recommended to avoid SQL injection attack vulnerability.
    See:
    Assuming that the ID column is an integer:
        FROM Video
        WHERE ID = <cfqueryparam value="#URL.VideoID#" cfsqltype="cf_sql_integer">
    </cfquery>
    References:
    CFQUERYPARAM
    http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461 172e0811cbec22c24-7f6f.html
    SQL Injection (Wikipedia)
    http://en.wikipedia.org/wiki/Sql_injection
    Mar 8, 2012 1:32 PM   in reply to JR \"Bob\" Dobbs
    You might consider refactoring your code to remove the dependency on a url scope variable.  This would allow you to use the CFC to query by video based on a form field or other value.
        <cfargument name="videoId" type="numeric" required="yes">
            FROM Video
            WHERE ID = <cfqueryparam value="#arguments.videoId#" cfsqltype="cf_sql_integer">
        </cfquery>
    </cffunction>
    CFM page:
    <cfset queryObj = myObj.pagevideo(videoId=url.VideoID)>
    Message was edited by: JR \"Bob\" Dobbs
    Mar 8, 2012 1:32 PM   in reply to TheScarecrow
    CFM page:
    <cfparam name="url.videoID" default="486">
    <cfset queryObj = myObj.pagevideo(url.videoID)>
    CFC:
    <cfcomponent>
    <cfargument name="videoID" type="numeric" required="yes">
            FROM Video
            WHERE ID = <cfqueryparam cfsqltype="cf_sql_numeric" value="#arguments.videoID#">
        </cfquery>
    </cffunction>
    </cfcomponent>
    Update: I discovered only after posting how similar this is to JR \"Bob\" Dobbs' suggestion!
