georgeduck
Can I get photos from iPhoto into Lightroom 3 (or/and 4)?
Feb 15, 2012 6:51 PM
I have PSElements 10 and iPhoto (iLife) 9.  I am looking into purchasing LR-3 or the trial on LR-4.  I have 10,000 photos in iPhoto.  Can I bring them into LR?  Individually?  By folder?  If they are brought into LR and also are in iPhoto, are they really on my computer twice?  Thank you!
    Feb 17, 2012 7:59 AM   in reply to georgeduck
    You can import images into Lightroom from any hard drive (this could be your internal hard drive). I'm not an expert on iPhoto, but if your iPhoto images are stored on a hard drive (they should be), you can import them into Lightroom, you just need to find out where they're located.
    When importing images into Lightroom from a hard drive, you can import the entire collection of images
    (note: Lightroom will import original/unaltered versions of images unless you edited images with a software that uses .xmp).
    Mar 6, 2012 10:13 AM   in reply to Marek Mularczyk
    Does this imprort use the current files or creates a duplicate version of those files on the hard drive (two sets)?
    Mar 6, 2012 11:57 AM   in reply to kdoerner
    When you import files into LR4, you have the option of adding them to the catalog in their current location (no copies are made) or having LR4 create copies in folder of your choosing.  So you should be able to have LR build a catalog of your image files without duplicating them or moving them elsewhere on your hard drive.
    However, I have never used iPhoto before, so I'm not sure if there are any conflicts that might cause iPhoto and/or LR4 to choke on files that are shared between the two applications.  I suspect it should work fine... but I can't say for sure.
    Mar 6, 2012 12:25 PM   in reply to kdoerner
    Dealing specifically with iPhoto. Original or duplicate is your choice. At this point, I would recommend a duplicate, that way the images are still in iPhoto and unlikely to be changed by anything you might subsequently do on Lr. I appreciate that 10k of images is a big number to duplicate, but is by far the safest approach.
    First thing you need to do is locate the iPhoto library package (normally located in Pictures folder). Using right mouse button or Ctrl+clicking on the pacakge you need to choose Show Package Contents. In there you should see a bunch of folders, you want the folder named Modified as it will conatin copies of all your image (edited and unedited). make a duplicate of the folder and place in your Pictures folders (or whereever you kepe your images). You can now import the duplicated images into Lr using the Add option in Import window.
    Note - above procedure is required because Lr currently has no way of accessing the contents of the iPhoto Library package.
    Mar 6, 2012 12:47 PM   in reply to Ian Lyons
    I know this is the case for LR3, but it looks like LR4 has the ability to use existing folders, does this exclude the iPhoto package?
    Thanks for all the tips.
    Mar 6, 2012 12:56 PM   in reply to kdoerner
    Folders and Packages are different. The Lr import window doesn't even see iPhoto Library package, let alone allow you to lok inside. I suspect you might looking via the Import from Application from File menu, which curretly doesn't do anything. If that is the case you'll find that the iPhoto pacakge is grayed out.
    Mar 8, 2012 12:28 PM   in reply to Ian Lyons
    I'm trying to use this feature and it don't work, and no one knows how it works, i called to Adobe phone and they don't know too. Well its strange to build something that don't work, or if needed extra application its not avaible. I'm really sad, i have a big Aperture Library and Bought this application (LR4) because the marketing was telling that it was possible...
    Mar 8, 2012 1:17 PM   in reply to GustavoPellizzon
    Good to know that you can't import the iphoto library using LR4.  I was going to upgrade just for this feature.  Your right, it does say you can use existing libraries to import photos, I wonder if they will fix the apple interface?
    Date: Thu, 8 Mar 2012 13:28:52 -0700
    To: kdoerner@hotmail.com
    Subject: Re: Can I get photos from iPhoto into Lightroom 3 (or/and 4)? Can I get photos from iPhoto into Lightroom 3 (or/and 4)?
        created by GustavoPellizzon in Photoshop Lightroom - View the full discussion
         Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Re: Can I get photos from iPhoto into Lightroom 3 (or/and 4)?
         To unsubscribe from this thread, please visit the message page at Re: Can I get photos from iPhoto into Lightroom 3 (or/and 4)?. In the Actions box on the right, click the Stop Email Notifications link.
         Start a new discussion in Photoshop Lightroom by email or at Adobe Forums
      For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
    Mar 8, 2012 1:25 PM   in reply to GustavoPellizzon
    Gustavo
    I'm not sure what you mean by "the marketing" - I've not seen anything from Adobe that would mislead you. In any case, if you search this forum you will find that there are already good ways to import your images and metadata from Aperture. If you can't find them, start a new thread and I'll walk you through the process.
    There's an overview at http://lightroomsolutions.com/migrating-from-aperture-to-lightroom-whe re-do-i-begin/. If that doesn't make sense, start a new thread here.
    John
    Mar 8, 2012 1:31 PM   in reply to johnbeardy
    At Lightroom 4 Features:
    Import of other libraries
    Bring the power and elegance of Lightroom to all your images, new and old. Easily import photos from other applications. "
    And there's a feature in the LR called "Import from Application" but there's nothing about it over the web. Just old ways to transfer the files with hard work for large library.
    Mar 8, 2012 1:42 PM   in reply to GustavoPellizzon
    OK, I see what you mean. Thanks.
    As it is, those "old ways" work perfectly well and aren't hard work if you are reasonably competant. You may also be able to control the process better and migrate information like the album structure.
    John
    Mar 8, 2012 2:01 PM   in reply to johnbeardy
    I know, but i have a managed Library... And ive readed that with this new feature it will automaticaly generate JPG from the developed images, by this way you are in Lightroom with your Originals and the JPG of the developed images in Aperture. Since both programs develop images in a complete different way. It is different than just transform my Library into a Referenced one and import the images from the folders. By this way when i open the Original in LR i will loose the adjustments made in Aperture. Do you understand!?
    Mar 16, 2012 4:50 PM   in reply to GustavoPellizzon
    I'm a newbie to LR and have downloaded the LR4 demo hoping to use it with iPhoto 09.  I'm basically OK with the Mac but not an expert and would like to point out a couple of problems I had which might make others think twice about 'experimenting'.
    To access your iPhoto files, go to the finder, locate your iPhoto library, right click on the library icon and scroll down to 'Show Package Contents. A new window will open with various files and folders including Modified and Originals.  I'm shooting Canon RAW and all my CR2 files are stored in the Originals folder in dated folders.  From here on in I'm a little out of my depth but I believe the Modified folder holds .jpg files which are copies of the CR2 files which iPhoto uses when showing photos in Events and editing.  They may also have some auto corrections applied so they look brighter and more saturated than the original CR2s.
    The easy way to allow LR to 'see' these folders and files is to create an alias of the iPhoto library or the Originals folder and ask LR to import from the alias and this does work *but* I did something wrong and this is where you can start to screw things up in a big way.  First, I didnt find it easy to understand the way that LR stores (or links) photos in Folders and Collections, second I found the import options slightly ambiguous so I tried to import just a few photos from 2012 / March (in the Originals folder) which worked fine.  Then I did the same for Feb which worked fine.  Then I imported the whole Originals folder and I was impressed, LR imported all the folders from iPhoto with identical dates and each dated folder had all the photos.
    All well and good but when I next opened iPhoto my February and March photos were missing so I guess I must have used the wrong import option but I thought, probably mistakenly, that LR didnt touch the original files it only created links.  Perhaps someone could help on that one.
    Next, I tried a Time Machine restore on iPhoto which took ages and didnt salvage the missing photos so I copied the missing photos from a Time Machine backup using the finder to another folder and reimported them into iPhoto which worked. Great. And then Time Machine encountered an error (not enough space on backup disk), all backups were lost and I had to reformat my external drive to get Time Machine functioning properly again.
    My apologies for this long winded summary but I really wanted to explain that it looks like LR4 can import from iPhoto (and do it really well) if done correctly and it would be really good to have someone (at Adobe?) with more experience than myself to write up a list of instructions for Dummies.
    One final point, LR4 is using different basic adjustments to photos with a 2012 process which differs from the 2010 process in ACR which confuses things more and there's a beta version of ACR using the same 2012 process which I've downloaded. Took me ages to understand what was going on (and why exif wasnt showing / saving correctly) ...  And very finally, there's other things I found out only by trial and error that are far too long winded to explain here!
    LR4 looks really good but is sadly missing some very important instructions when it comes to importing from iPhoto 09.
