Hi everyone,
The level one headings in my document look like the following:
Chapter 1
Name of chapter
The chapter number, ie. "Chapter 1" is 24 points in size with 25 points of leading. The name of the chapter below it is 16 points in size with 28 points in leading. There's a soft line break after the chapter number to force the chapter name onto the second line without creating a new paragraph.
I need the soft paragraph so that when the table of contents is automatically generated, the two parts will stay together without a separate paragraph. The problem is that when the TOC is generated, the two separate font sizes are being applied to the two separate parts of the heading. This happens even though I've created a TOC Level 1 style and this gets applied when the TOC is rendered. I'm having to go through and apply "clear overrides" on each of these level 1 headings.
Is there a way to prevent the TOC from picking up the two sizes so that it just treats it as raw text and then applies the TOC Level 1 heading after it's generated?
Appreciate any advice.
Hi gwhPoster,
Are you using Character Style?
Clear overrides don't take out this styles.
If not, try created some and apply using "Drop caps and Nested styles" into the style.
I usually apply "regular" character style to take the changes in the text to the default TOC style that I created.
Wagner
Two possibilities. First is the styles are still also applied outside the nested style -- select the entire paragraph, then go the the Character styles and select None to only use the nested styles. Second is you are using the same style for you listing (or one based on it) that still has the nested styles included in the definition -- create and use a new style for your listings that does not include any unwanted nested styles.
I just checked and there's definitely no character style appled outside of the nested style. There's also no nested style in the TOC style definition.
The odd thing is that the first chapter heading comes out ok, ie. no need to clear overrides. It's only the second and following ones that are not working.
I can't work it out.
If you put your cursor in the text in the TOC that is the wrong size, what do you see for Character style?
Now move to the chapter and put your cursor in the same place, and what do you see? Is the size a local override, perhaps (do you see a + sign after the Paragraph Style name)? Alt/Opt click the Paragraph style name to remove local overrides from the paragraph.
I see None in the character style.
I still see none in the character style and there's no plus sign next to the paragraph style. If I put the cursor in the larger text in the main chapter, I see none in the character style but at the bottom of the character styles panel, I see the name of the character style (if you know what I mean). If I put the cursor in the other section of text, I only see none in the character style.
So unfortunately, still no resolution. Maybe I should just delete the style and start again.
Since the first chapter was working, I ended up just copying and pasting that into the other chapter sections and then retyping the correct chapter number and name.
When I updated the TOC it was all working.
I still have no idea why because chapter 1 looked identical to the other chapters but it seems to have worked.
Thanks though for all your advice - really appreciate it.
