This is the first time I've had this happen and haven't been able to solve the problem yet and haven't found any solutions yet through searching. Using CS5.5, I'm building a show consisting of 7 or 8 already rendered sequences. All seem fine when put together, but one sequence is thrown way out of sync when I import it. The file plays fine otherwise and it isn't until it's imported into premiere that the problem occurs. I've tried re-rendering several times and get the same out of sync problems. And it eventually gets wildly out of sync, not just a few seconds. The properties of the clip are:
Type: MPEG Movie
File Size: 1.5 GB
Image Size: 1920 x 820
Frame Rate: 23.976
Source Audio Format: 48000 Hz - compressed - Stereo
Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
Total Duration: 00:04:23:09
Average Data Rate: 6.0 MB / second
Pixel Aspect Ratio: 1.0
This is the same as all the other rendered/imported sequences. I'm at a loss here. Is there anyone who can help steer me to solving this?
Yes, thank you, Bill. That's exactly what I meant. I have many such sequences exported and never had a problem with one until I noticed that one of the exported sequences is grossly out of sync after importing them into a new project. I've tried re-exporting several times, but cannot figure out what makes this sequence different from the others.
I spent most of the afternoon playing with it and it corrected itself. I wish I could know exactly why it did it, but there doesn't seem to be anything different I did with that sequence as opposed to other ones. I will chalk it down to, just one of those things, but it's an unsettling one of those things. Thanks for your help.
