Hi Thanks for bringing this issue. I am having same issue when I plugged in my Intuos4 with Photoshop. If Intuos is unplugged everything is working normal but when I plug it in, I can't move stuff with my trackpad (still able to move with pen and arrow keys) along with other issues people are reporting here.
Please fix this issue ASAP.
Thanks, Harjinder
Hi everyone,
I'm experiencing the same problem with the snapping using Photoshop CS5 with the Wacom Intuos 4. Objects will not move properly after a while of usage, resulting to having to shut down the program and start again (problems starts again shortly after).
Has there been a solid solution to this problem yet?
Specs:
- Latest Wacom driver installed
- Lion latest version
- Photoshop CS5 (latest installment)
- No additional apps besides internet browsing
Yes. The one that I have problems with is at work and it is close to my speakers and pen. And, it seems it happens more often then not when it is windy outside. Maybe it has something to do with static electricity. I'll ask our IT consultant if he has ever heard of this problem with other designers and get back with you all.
Hello,
I think I may have found the culprit. I started using Adobe PS CS 5 Extended the same day I received the Wacom Intuso 4 (about one year ago) and NEVER had a problem until last month when I added Adobe PS CS5 into the application section, see below.
This is the ONLY change that I made to my wacom settings beside the typical button layout.
I just tested this out. I removed the Adobe Photoshop CS5 from the field Application field and restarted Photoshop WITH the tablet plugged in. Now, I can use both the track pad and the tablet. See below:
Just to test my finding, I readded the application BACK to the application field (Photoshop was shut down; pen and mouse three feet away) and modified my settings like I wanted, then I started Photoshop.
At first, I was able to use the track, but as soon as I used the pen, the track pad stopped functioning properly and the "jump back" problem started again.
I only have Flash Player and Wacom in the other field on System Preferences, see below.
In this case it doesn't matter weather the pen is sitting on the tablet or not. Once Photoshop is removed from the Application field of the Wacom settings, the track pad and tablet work in harmony.
I hope this works out for you and helps Adobe/Wacom find a solution/fix to the problem.
Brandon
Message was edited by: numeroeins
numeroeins, you're right! Only it's not just Photoshop. I didn't have Photoshop entered in the applications section, but I did have Lightroom in there. I removed Lightroom, and now dragging works properly with the tablet in Photoshop. It's a pity that I have to choose between dragging and application settings, but dragging is something I need to do on a regular basis.
Kudos to you for finding this bug!
I'm not sure if this is the solution or not...though I really, really want it to be. I checked my settings, and I didn't have any application specific settings enabled. I enabled them, and then disabled them, and then restarted Photoshop...and both worked well! Though, are you sure that it's not just restarting Photoshop that fixed the problem? Also, why did it occur on my system, where no application specific settings were set?
Either way, both are working together now, which is a very nice change of pace. I'm wondering if the effects will continue to last after a few restarts (hope they do!).
Also, even if this is the solution...Adobe or Wacom really needs to address this. Users shouldn't have to decide between two useful functionalities.
No, I don't believe it was the restart. Ever since I removed Photoshop from the applications specific settings, I left it running with the tablet connected to my Mac. The track pad and the tablet were both flawless for well over 6 hours and this morning. --I'm in Kuwait.-- Everything was connected and runing all night.
Did you test them both when you enabled them? I see that your wrote, "enabled them, then disabled them."
Here are the exact steps I took to test my finding:
Shut down Photoshop, tablet should be connected, enable the application specific setting under Wacom, make a change to the tilt or anything other than the default settings used on all applications (like I did by adjusting my tilt), start photoshop (leave everything connected), open an image, drag something on top of that image, use the track pad to move layer one (if named so), then use the pen to move the item, and finally try the track pad again. It should jump back to the same spot.
My drivers are up to date. Software is up to date.
As another test, since you mentioned restarting Photoshop, I left Photoshop running this time and added the application specific settings.
Here are the exact steps: Photoshop running, tablet and pen connected, pen is about 2.5 inches from the tablet, added Photoshop to the application specific settings, made a change to the tip pressure and tilt (anything than the default settings), closed the system preferences window, returned to photoshop, opened two images, used the track pad to drag an image onto the other (creating a new layer), then I used the track pad to move it around from top to middle to bottom and back, no problems, I then used the pen to move the image to the middle and that was it, and finally tested the track pad again just to find out I have the jump once again.
In order to remove the jump, of course I have to remove the application specific settings, then restart Photoshop. Just removing the settings alone, will not clear the jump.
Please note that I'm being thorough in my steps due to the fact that one slight deviation could make a huge difference in the outcome. That is why I'm asking you about the "enable them, disable them" steps you mentioned.
Anyways, I'm glad it is working for you please do let us know if it stops working again.
To: Adobe Employees. Have any of you tested this out in house?
numeroeins, I tried your fix, and had no luck. It's awesome that it's working for you, though.
I didn't have PS in my Wacom's Applications field. I added it, then subtracted it, all following your instructions, and the problem persists.
I'll probably have to hold off upgrading to CS6 if it's showing the same issue. Step one will have to be getting a new tablet. Maybe that's why Wacom is so silent on it.
