pao1011
undefined resutl tryng to get data to flash with php
Mar 8, 2012 6:32 PM
Hello there,
I'm not   coder but I understand well the way it work and can manipulate script already written. I cross with a problem that I do not understand why is happening. I a AS3 and php getting the results from the database. The php is working fine since I test it. but the request from the flash give me a result of "undefined" .I have a text area on the flash file in which is supposed to show the results from the php. This code so far:
AS3:
import flash.display.*;
import flash.events.*;
import flash.net.URLLoader;
import flash.net.URLRequest;
import flash.net.URLVariables;
import flash.net.URLLoaderDataFormat;
import flash.net.URLRequestMethod;
// Assign a variable name for our URLVariables object
var variables:URLVariables = new URLVariables();
//  Build the varSend variable
var request:URLRequest = new URLRequest();
request.url = "ckBxSample_disp.php";
request.method = URLRequestMethod.POST;
request.data = variables;
// Build the varLoader variable
var varLoader:URLLoader = new URLLoader();
varLoader.dataFormat = URLLoaderDataFormat.VARIABLES;
varLoader.addEventListener(Event.COMPLETE, completeHandler);
try
    varLoader.load(request);
catch (error:Error)
    trace("Unable to load URL");
// Handler for PHP script completion and return
      function completeHandler(event:Event):void{
       // Load the response from the PHP file
      if (event.target.data.returnBody == "") {
        output_txt.text = "No data coming through";
      } else {
        output_txt.condenseWhite = true;
        output_txt.htmlText = "" + event.target.data.returnBody;
// Send the data to the php file
// Ready the variables for sending
variables.requester = "phpRows";
in the php :
if ($_POST['requester'] == "phpRows") {
sql connection code
then mysql query here
$sql = mysql_query("SELECT blah bla bla
//then the while loop for all records I want to pull
while($row = blah ){
//calling the rows
$id = $row["id"];
//sending th results to be calle by flash
$body = " $id ";
//flash results
print "returnBody = $body";
//close con
    mysql_close();
    exit();
This is most the code and I get a undefined result in the textarea in flash
can anyone help? please
thanks in advance
Replies 1 2 Previous Next
  • kglad
    Jul 21, 2002
    Mar 8, 2012 10:16 PM   in reply to pao1011
    use:
    try
    catch (error:Error)
          } else {
    in the php :
    sql connection code
    while($row == "blah" ){
    //calling the rows
    $id = $row["id"];
    $body = " $id ";
    //flash results
    //close con
        mysql_close();
        exit();
  • kglad
    Jul 21, 2002
    Mar 9, 2012 6:35 AM   in reply to pao1011
    yes, it matters.
    copy the changed code you're using and paste it here.
    Mar 9, 2012 7:12 AM   in reply to pao1011
    You are returning WAY too much information, a whole HTML page. You can't do that. You need to strip the response so the only thing that's outputted from http://digicinelatino.com/flash/ckBxSample_disp.php is literally this:
    returnBody=George+Juarez
    The vars need to be in URL encoded format.
  • kglad
    Jul 21, 2002
    Mar 9, 2012 8:17 AM   in reply to pao1011
    you're not using the code i suggested.  aqain, order is important:
    Mar 9, 2012 8:36 AM   in reply to pao1011
    Let me rephrase. You're looking at the page http://digicinelatino.com/flash/ckBxSample_disp.php in a browser. Flash is not looking at that page like a browser, it is looking at it like raw text. In other words, view source on that page and look at what flash sees. It does not just see:
    returnBody = Some Dude
    It sees:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">...........etc
    What you want to send as a response back to flash is a GET encoded response. Nothing else and certainly not in a HTML page.
    Make this file: result.txt and ONLY add in this:
    Then change the line:
    to:
    request.url = "result.txt";
    See what you get back in returnBody.
    Mar 9, 2012 10:16 AM   in reply to pao1011
    If you need to send a lot and/or complex amount of data then consider JSON. There are plenty of links at the bottom of the page for JSON encode/decoders that make it really easy to send data from one place to another. LoadVars-esque techniques never really suited me. Anyhow of course you can use the PHP, but you need to edit the PHP page itself so it stops spitting out all that HTML around it. What you should end up should look exactly like the text file above.
    Again, I'm not suggesting use a text file. I just wanted to show you it is working properly but you're not formatting your response to flash properly. The text file shows you what you need to do. Now modify the PHP so it strips out all the HTML crap and just format the response properly.
    Mar 9, 2012 11:14 AM   in reply to pao1011
    You need to format your response like a GET encoded URL. You are putting new lines (\n) in your response and that will screw it up.
    // valid response:
    userAName=Joe&userAID=31&userBName=Bob&userBID=32&userCName=Jack&userCID=33
    // INVALID response, makes no sense to flash
    Joe 31
    Bob 32
    Jack 33
    You also need to strip out the HTML from your response. You still have HTML crap in there. Nothing but the data should be printed. No <!DOCTYPE html PUBLIC "-//W3...... etc. Strip all that crap out. View your pages source that returns results to verify you removed it.
    Mar 9, 2012 1:36 PM   in reply to pao1011
    Sure, but in that case you don't want to use the URLLoaderDataFormat.VARIABLES if you just want to print a formatted string into a htmlText. What you're trying to do is properly format it so flash can generate variables from the text you're reading. And yes, PHP needs to be executed so it needs a server.
    If you just want to dump a string in a htmlText then use URLLoaderDataFormat.TEXT. Then dump the response into some dynamic text field. There's no need to convert it to variables unless you need to break the data up in a controlled way into separate variables.
  • kglad
    Jul 21, 2002
    Mar 9, 2012 4:15 PM   in reply to pao1011
    copy and paste the following and upload your files to a server.  post a link to your embedding html.
    //varLoader.dataFormat = URLLoaderDataFormat.VARIABLES;
    try
    catch (error:Error)
          } else {
            output_txt.htmlText = "" + event.target.data;
  • kglad
    Jul 21, 2002
    Mar 9, 2012 6:15 PM   in reply to pao1011
    again, upload your files (html, php and swf) to a server.  post a link to your embedding html.
  • kglad
    Jul 21, 2002
    Mar 9, 2012 10:07 PM   in reply to pao1011
    now, fix your php and retest.
    <php
        //I remove the if condition to show the result from the database
        //request from Flash
                   ($_POST['requester'] == "phpRows") ;
    //Connect to the databese
    include_once "connect_to_mysql.php"
    $tbl_name = "table_name";
    $body = "";
    $con = mysql_connect($mysql_hostname, $mysql_user, $mysql_password)
    or die("Opps Fail to connect to the host");
    mysql_select_db($mysql_database, $con) or die("Opps fail to connect to database");
    $sql = mysql_query("SELECT * FROM $tbl_name");
    $result=mysql_query($sql);
    while($row = mysql_fetch_array($sql)){
    $id = $row["id"];
    $uname = $row["uname"];
    $client_song = $row["client_song"];
    $body = "$id&$uname&$client_song";
    print $body;
        mysql_close();
        exit();
    Mar 10, 2012 8:41 AM   in reply to pao1011
    You do not need to stick with the VARIABLES route.
    However, if you do, you are STILL printing out an empty line before you print your variables. You also are not providing a variable name for all the variables being returned. You also are not urlencoding your results.
    Here is what your script is printing out:
    returnBody= 37&George Juarez&Los del Rio - La Macarena"
    I added the quotes myself for representation. Notice the quote starts, then an empty line, then on the next line your data begins? You can't do that. Get rid of the empty first line. You have to think from a code perspective, not human. Your code doesn't know your first line, which is empty, isn't what you want. That's why you get no response in variable form.
    Second, you have to assign a variable name to every piece of data. That means you want to assign a variable name to the data '37', another to 'George Juares', another to 'Los del Rio - La Macarena'. You also should not have anything invalid in an URL, such as a space. A space is represented by %20.
    What you should be trying to do is something like this:
    id=37&name=George%20Juarez&location=Los%20del%20Rio%20-%20La%20Macarena
    Then you will have assigned each piece of data with a variable name and will know how to access it separately.
    Note: You only want to url encode the values, not the variable names. You also want to keep the variable names to standard variable naming conventions. AS3 has a function to properly encode a string for you, called escape().
    For example:
    var value:String = "This is a string";
    trace(value); // This is a string
    value = escape(value);
    trace(value); // This%20is%20a%20string
    I still say you get away from the VARIABLE usage of URLLoader so you can keep the formatted version of the output you so desire. If you're going to use VARIABLES, then learn how to form the proper response. ALL of the information you need is right here.
    Mar 10, 2012 1:01 PM   in reply to pao1011
    Lets be really clear here. I'm going to actually type the same thing 3 times in a row so you understand it.
    returnBody is the name of a variable.
    returnBody... is... the... name... of... a.... variable.
    Stop fixating on "returnBody". Please.
    The convention I'm trying to help you understand is this:
    var=value
    That is it. If you need more than 1 value, then you separate them with an ampersand (&).
    e.g.:
    var1=value1&var2=value2
    That means you sent back 2 variables. If you traced the value of var1 it would be 'value1'. If you traced var2 it would be 'value2'.
    This is a concept that has elluded you this entire thread. Stop trying to send back the whole result wrapped inside this 'returnBody' variable. Learn that I'm trying to show you how to return the values and assign them to separate values so you can use them how you wish.
    If you want to just print the output of the PHP files results, then use the code that has been shown above. Do not use VARIABLES, use the TEXT version of URLLoader and send the data returned directly to a dynamic text field using its htmlText property.
    Otherwise hire someone that understands actionscript and the web.
  • kglad
    Jul 21, 2002
    Mar 10, 2012 1:19 PM   in reply to pao1011
    upload Scripts/swfobject_modified.js
  • kglad
    Jul 21, 2002
    Mar 10, 2012 1:25 PM   in reply to pao1011
    Mar 10, 2012 1:42 PM   in reply to pao1011
    Nobody jumps in here just to give you grief. When you understand how to format a "GET" formatted URL string as well as understand URL encoding you will read this thread again and realize the answer has been supplied to you multiple times.
    My apologies if you think I'm insulting you but if you are told 1+1=9999 and we tell you 1+1=2 and you continue not to listen, you may be called on it.
  • kglad
    Jul 21, 2002
    Mar 10, 2012 1:43 PM   in reply to pao1011
    you still have
    print returnBody=$body;
  • kglad
    Jul 21, 2002
    Mar 10, 2012 2:39 PM   in reply to pao1011
    humor me and upload your swf's embedding html, change your php to print $body and post a link to your embedding html.
  • kglad
    Jul 21, 2002
    Mar 10, 2012 2:55 PM   in reply to pao1011
    1.  open your swf's fla in Flash Pro
    2.  click file/publish settings and make sure html and swf are ticked.
    3.  click file/publish.  don't use dreamweaver and don't edit the html file.
    4.  upload the published html and swf to some directory on your http://digicinelatino.com server.
    5.  post a link to your uploaded html file.
    Mar 10, 2012 2:52 PM   in reply to pao1011
    to be honest ... there is a problem with the tutorial you are using
    Its overall php structure is
    setup mysql
    while there are records {
        form a result
    send result
    So if there is more than one result in the db, only the last one would be sent.
  • kglad
    Jul 21, 2002
    Mar 10, 2012 4:44 PM   in reply to pao1011
    you're still trying to access a returnBody property from that data string and you're still using the same problematic php code.
    "Flash is asking for return results from returnBody"
    returnBody=38&Paola F. Gonzalez&Shakira - Ciega, Sordomuda
1 2 Previous Next
