I'm working on a series of lessons about a database application. I've recorded 3 lessons with no problems. Of course today is different. I've set CP5 up to record a new set of screens and when I finish recording only the last slide is showing up on the filmstrip. I've checked and it isn't on FMR. Any ideas. I've ran through the simulation 3 times making sure I've clicked somewhere on each screen I want it to capture and no luck.
Thanks for any and all help.
Susan
When recording the simulation, are you able to hear the Captivate "camera shutter" sound each time you click? If not, does this shutter sound occur if you do a manual capture using the key assigned in your preference settings?
I have the sound turned down since I work in a cubical.
The problem resolved when I rebooted the computer.
Susan Wright (Equilady)
Remember, the mighty oak was just a nut that held its ground.
http://www.equilady.com
