Shiva.Kosaraju
Help required in accessing a file on shared path
Mar 1, 2012 5:18 PM
I am trying to access a file present in a shared location using a custom component. When i run my Java code the file is accessible. But when i deploy the same code on livecycle as a custom component, the code is not able to access the file.
The location of the file is as follows: \\Shiva\Test\tempExcel.xlsx
The path string i use in Java code is: ////Shiva//Test//tempExcel.xlsx
Can someone help me with this issue. Do i have to change the pattern of the file path when i am trying to access the file from adobe livecycle custom component?
In case i need to provide permissions to livecycle for accessing the Excel sheet please suggest on how i should implement the same.
    Mar 2, 2012 12:40 AM   in reply to Shiva.Kosaraju
    readResource content operation will fetch documents from Adobe Repository. Unless you checkin the required file into repository, the above error will remain.
    From a shared folder, you should able to read the files using readDocument (using FileUtils) without any issues. Perhaps, the access rights prevent the execution.
    If you are running JBoss as a windows service (turnkey will create a windows service for the JBoss instance), try the following:
    Run -> services.msc -> Right click on JBoss service for Adobe LiveCycle -> Properties
    Check the value given under logon tab. The User Account mentioned there should have appropriate access to the shared folder you are attempting read.
    Nith
    Mar 12, 2012 2:40 AM   in reply to Shiva.Kosaraju
    The path just looks fine. Contact your administrator to make sure that the path is accessible from the server.
    Nith
