The "LightroomPatch.reg" solution mentioned above seems reasonable, but I get the following error when I attempt it on my Win 7/64 machine. (No PS software loaded...only LR3 and 4 and Nik/Topaz plugins).
"Cannot import 'C:\...LightroomPatch.reg; the specified file is not a registry script. You can only import binary registry files from within the registry editor." Should I just continue using LR3.6 when I need to access the plugins and wait for whatever solution Adobe will be offering? Thanks
Hallo Beat,
I do not have Nik plugins, but Portrait Professional 10 set up as additional external editor (http://www.portraitprofessional.com/support/?qid=58).
When I try to invoke an "Edit in" LR4 creates the desired copy, but fails to open the external editor or hand it over if I have opened it manually.
Could it be that I need a smilar reg-patch?
I have PS5 installed, and handover to it works (when I let LR4 translate the camera raw version).
Thanks for your thoughts,
Cornelia
P.S.: a completely different question: how do you manage on this forum to link to a specific response, rather than the beginning of a thread?
Hallo Cornelia,
Easy things first ![]()
Each post contains a title in bold, which links to the very post itself, within the thread.
I kind of doubt that your problem is the same as what people without CS5/PSE installed are experiencing.
Have you tried to set up something else as an external editor, i.e. MSPaint (C:\Windows\System32\mspaint.exe) and see if the image opens with it?
Beat
P.S: Do you know how to handle RegistryEdit in Windows? If so, you could check if the registry key mentioned ([HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Photoshop.exe]) is present on your system.
Hi Beat,
Yes, I know how to handle RegistryEdit as long as I have very clear instructions ("dressierter Affe"
This Registry key for Photoshop.exe is not present, so I might follow this http://forums.adobe.com/message/4258402#4258402 first.
Cornelia
