Frustrated_Frank
Flash Player won't install
Dec 17, 2008 3:40 PM
Using IE, and Firefox. Every time i try to install Flash player ( http://get.adobe.com/flashplayer/)
i get this message
"Failed to install. For troubleshooting tips, please see http://www.adobe.com/go/tn_19166"
I've gone through all the steps. I keep getting the same problem. What can I do to fix it?
running vista 64 OS
Any help would be appreciated..
    Dec 18, 2008 6:06 AM   in reply to Frustrated_Frank
    I'm experiencing the same problem (frustration) as well using WIndows XP Pro on a Dell D820. I've removed virus protection, pop up blockers and still getting the same messages that Flash Player 10 won't install (not getting the Active X popup). Version 9 worked/installed fine but it seems I can't reload V9 anymore either.
    HELP!!!!!!!!!!!!!!!!!!
    Dec 18, 2008 7:17 AM   in reply to Frustrated_Frank
    Im having the same problems as everyone else stop background programs the use flash.uninstall with tool done the reset zip tool with microsoft program together.DONE what that hyper link has suggested and still here i am .until the issue is cleared up and i have gotten some help from adobe im running firefox ....SO HELPPPPPPP PLEASE
    Dec 19, 2008 9:06 AM   in reply to Just_the_FACTS
    i had adobe 8 and received a message to up-date to 10.0. i followed steps, would not update and lost 8. i uninstalled using /go/tn_19166 and reinstalled 8 with /go/tn_14157. now i can view some items and get radio back but, there are now some items i can't view i could before? what is a reg. error? is there anyone out there having any success?
    Dec 20, 2008 1:34 AM   in reply to Frustrated_Frank
    Hi Frustrated_Frank-
    You'll have to run your IE7 in 32bit for FP to install/work. Adobe FP is not available for 64bit browsers yet.
    See the thread "32 bit browser on 64 bit Windows 2008 Server" for relevant info, it's currently on page 2.
    Also if you run a search on this forum, like "Vista 64 bit" you'll find some relevant threads.
    Dec 21, 2008 10:29 AM   in reply to Frustrated_Frank
    here is why you can't install it
    yr browser have to allow pop-ups in order flash to be installed - they are disabled by default in all browsers
    BEST WAY TO DOWNLOAD FLASH
    go to http://www.filehippo.com and download it from there
    file hippo is the only download web site that does not require yr pop-ups to be enabled and while you are there check top right side and download small application that will tell you if yr software is up-to-date - you can up-to-date all yr software right from there free of charge
    hope i helped
    this helped to some who were unable to install flash - i gave them this answer in yahoo answers and it helped but really do not know if they had 32- or 64-bit windows
    Dec 23, 2008 3:11 AM   in reply to Frustrated_Frank
    Hi Frustrated Frank-
    So you've made sure that your AV/IS or Windows Defender isn't blocking this? There have been Kapersky IS problems.
    Verified in IE Tools/Internet Options/Security/Custom Level/ActiveX that "Run ActiveX plugins" is enabled?
    On the same page that the error refers you to (tn_19166), down near the bottom is an executable zip file: Install_Flash_Player_10_Activex.zip. Have you tried that? It's worked for some.
    Look at this (from forums.techarena.in) http://www.softwarepatch.com/network-security/flashdownload-security
    try it if you wish, claims to fix the download issues(?).
    Cnet and filehippo just link back to Adobe.com, but are faster.
    I'm trying to remember/locate the link to the FULL version of FP10 (8MB). Haven't found it yet (sorry).
    Dec 27, 2008 9:13 PM   in reply to Frustrated_Frank
    "The publisher has been blocked from running programs on your machine". Are you getting this message when you try to open the
    Adobe uninstaller or when trying to open the standalone installer for Flash Player 10?
    You are getting this message because for some unknown reason Adobe Systems Incorporated is getting listed in the untrusted publishers
    tab in IE7. I looked at the installation file and it says the security certificate was revoked on Dec 10, 2008 which may be causing
    this issue, however, whatever the reason that it is being listed there, can be solved.
    In Internet Explorer:
    1. Click on tools
    2. click on internet options
    3. Click on the Content tab
    4. Click on the Certificates tab
    5. Click on the Untrusted Publishers tab
    6. If you see Adobe Systems Incorporated listed there, highlight it and then click on Remove.
    You should now be able to use the adobe uninstaller program to remove any previous versions of Flash Player
    and install the newer version of Flash player. I am running Vista with IE7. This may also work for Windows XP
    IE7 if you are having the same problem but I have not tried this remedy on that since I haven't experienced that on
    my other computer that runs Windows XP. And for what it's worth, Flash Player 10 works great. Also, if you tried to
    find help in the Windows help files on how to do this, you have wasted your time. Microsoft's help files are no help
    at all on this issue as they don't give any specific information on how to unblock a publisher. I hope helps.
    Dec 31, 2008 4:55 PM   in reply to Frustrated_Frank
    The www.filehippo.com worked for me, but only by installing Flash Player 9. Flash Player 10 failed at "Registering: C:\WINDOWS\system32\Macromed\Flash\Flash10a.ocx" on our sons' computer. It is running IE7 on XP Home. FileHippo.com
    Jan 1, 2009 5:57 PM   in reply to KBKLC
    I am haveing the same problem as "Frustrated_Frank". I have tried all the suggestions provided here to no avail. Problem just started when I went to a website and it said I needed the new version to view the site. From there all hell broke loose. Now I can't view anything as it had me uninstall the older version. I get the same "Failed to install. For troubleshooting tips, please see http://www.adobe.com/go/tn_19166".
    Any new suggestions??
    Jan 1, 2009 9:49 PM   in reply to Upstatepano
    When you uninstall a program from windows xp or vista, there are files leftover in the registry. Windows XP always did have a problem removing every single file when a program is uninstalled,especially when files are written to the registry. It never fails, no matter what program I decide to uninstall from my computer, it's guaranteed every time that I will find leftovers. Vista seems to do a better job at removing software programs but it too has the same problem. That being said, when you uninstall a program, especially one that also wrote files to the registry when you first installed it, you can be sure that those files left in the registry will cause problems for the new installation. Make sure all files of the old flash player are removed, including the ones in the registry before installing the new one. With Vista, no matter how clean your system is if the publisher's security certificate is revoked, Vista WILL NOT install that software until it has a valid security certificate or until you remove it from the untrusted publishers list in IE7. That may not be your problem but it is worth double checking. Also, adobe flash player needs certain system files (files that are part of Windows) to be present or the install will go all to hell. Once the old Flash Player is uninstalled and your system is totally clean of it, go to Windows update and make sure IE6 or IE7, whatever one you have, is totally updated and any other windows components are updated. That may or may not solve your problem but it is one less possibility to get out of the way of what could be causing your problem. I will tell you this one thing for sure. On a clean Windows install, XP or Vista, I have never experienced a problem installing flash player. Either something is missing or something is in your system that should not be there.
    Jan 2, 2009 2:06 PM   in reply to Bruno_Dude
    UPDATE: I have had mine fixed! As stated in the error message when you visit that page it is a registry problem. I am not savy enough to fix it myself so I had our office tech look at the error message. He had it fixed in a few minutes. He had to go to the Microsoft website and downloaded the "fix" mentioned here "Failed to install. For troubleshooting tips, please see http://www.adobe.com/go/tn_19166" . He repaired the registry and then downloaded from Adobe a "manual downloader" and manually loaded the latest version of flash. Don't know if the manual download was necessary but he used it anyway.
    Hope this helps others. Thanks very mush for all the information submitted here.
    Jan 3, 2009 9:05 AM   in reply to Frustrated_Frank
    I had to do a reload after getting hit with vundo virus. Trying to reinstall works 2006 but am getting Macromedia Flash Player 7 "INF install failure Reason: Unknown" Any ideas????
    Jul 22, 2009 12:27 PM   in reply to Frustrated_Frank
    i am unable to install adobe flash player automatically in my Mozilla forefox
    it is prompting me to do it manually. please tell me how to fix this problem.
    Jul 22, 2009 10:21 PM   in reply to thegetpr.com
    1. Download http://fpdownload.macromedia.com/get/flashplayer/current/install_flash _player.exe
    2. close Firefox
    3. install it
    Message was edited by: Pat Willener
    Aug 12, 2009 6:15 PM   in reply to Frustrated_Frank
    this flash player sucks trying to download for days
    Aug 14, 2009 1:19 PM   in reply to Frustrated_Frank
    running xp home, IE, tried over and over to install flash player and the Adobe download manager wants my proxy settings...have tried to type correct settings in and tried to hit the "no proxy" button and both attempts give me stalls at 0.0% and same message from download manager..."can't retrieve essential parameter (16236.301.375)...i have called my internet provider and technician has not heard of that before...we pinged...i have great connection...and NO PROXY...what the @#%^ is the deal?
    Aug 14, 2009 1:41 PM   in reply to NoDakDi
    resolved this issue by searching through forums...go to Adobe download flash player site and startt the download and click on the link further down the page for if the install does not start...do not click on the bar at the top of the page...it appears to be a older school download where you run or save to computer and start steps that way...i have finally got Flash Player!!
    Oct 1, 2009 11:15 AM   in reply to Frustrated_Frank
    None of these methods worked for me.  Forget the work-arounds!  Just uninstall Flash Player and install Shockwave Player!  This did the trick for me!  No more missing items on webpages and no more prompts to download Flash Player, which means no more freezes on the install.  Our IT guy said Shockwave Player is the newest version of FlashPlayer.
    Oct 1, 2009 7:29 PM   in reply to CG SF
    Flash Player and Shockwave Player are not the same!  Some sites need Flash Player, some sites need Shockwave Player, and some sites need both.
    Uninstalling Flash Player will not do you any good on sites where it's required.
    Mar 10, 2012 6:59 AM   in reply to Frustrated_Frank
    Hey wwwpirate: THANK YOU!!! I've been trying to get Adobe Flash player installed on my 32bit XP machine for about 8 months or more, receiving an error message on every attempt. YOUR METHOD WORKED! Thank you!
    Mar 10, 2012 7:00 AM   in reply to wwwpirate
    This worked perfectly.
