I Exported media in cs5 and only got audio  Help
Mar 1, 2012 10:09 AM
Don't see why I only get audio   see link  of my video  http://www.screencast.com/t/pGmzOoCUs
    Mar 1, 2012 10:37 AM   in reply to patrickfale
    Post screen shots of your settings screens
    Saying what you did is not as good as showing what you did
    Mar 1, 2012 11:35 AM   in reply to patrickfale
    You exported two files, one for video and one for audio.  This is normal for DVD creation (which I assume is the goal here, using an MPEG2-DVD preset.)
    Mar 11, 2012 8:42 AM   in reply to patrickfale
    Turn on multiplexing on export, creating a single .TS stream.
    Mar 11, 2012 9:29 AM   in reply to patrickfale
    Your sequence settings look incorrect. 1440x1080 29,97 while the clip shows 1920x1080 59,94.
    If you are going to dvd leave it like it is, but use a preset and do not use match source attributes.
    Import the . m2v and .wav into Encore.
    BTW bad practice putting files on the desktop.
    Under extra/view there is an option to reveal extentions, might want to turn that on.
    Not sure if its called extra/view as i am on a non English OS.
    What is your intended purpose for the video ?
    Is it to burn it to a DVD ?
    If not then MPEG2 DVD is not the best setting.
    The purpose of making 2 files ( one video and one audio ) has to do with how DVD players play the file.
    When the file is Muxed into one single file DVD players have to break apart the audio and it takes more work.
    Maybe other can expand on the reason of why not to Mux your audio and video better.  I read a good article on it but cant remember.
    GLenn
    Mar 11, 2012 9:42 AM   in reply to patrickfale
    Nope: dvd is mpeg2-dvd.
    Youtube is H.264 with a Youtube preset. Files for Youtube are video and audio in one.
    Mar 11, 2012 9:50 AM   in reply to patrickfale
    Mpeg2-dvd ntsc widescreen high quality.
    Best to leave it two files.
    If its one file Encore has to pull the audio from the video, do its encoding and then paste it back together again. Unnecessary action.
    But if you still want one file set the multiplexer to DVD.
    Mar 11, 2012 9:52 AM   in reply to patrickfale
    If you really want it in one file you can click the multiplexing tab and click it from none to DVD and it will mux it for you.
    If your trying to make a YouTube video use H.264 and choose the YouTube preset.
    Glenn
    Mar 11, 2012 11:02 AM   in reply to patrickfale
    You are most welcome.
    I do teach Premiere, but you will have to grab an airplane first.
