Hotrod2uk
Multicam Bug?
Mar 10, 2012 5:46 PM
Tags: #cs5.5 #bug #multicam
After editing many multicam sequences in CS5 and no issues I have slowly become more and more frustrated at this bug in CS5.5..
1. I create a sequence
2. I start clipping shots and making a single timeline edited sequence (intro to the multicam footage), after a min or so of edits on timeline one I eventually get to my multicammed bit and drag all footage in to their respective timelines. So when you look at the sequence yo have a min or so of footage on timeline 1, then a multicam sequence occupying time lines 1 - 4, after that.
3. I sync all the audio and render out a master audio WAV file for the whole sequence. I lock all video, remove all audio and drag in my new muxed track for audio 1.
4. Right Im all set, new sequence, drag in the sequence created above, right click on footage select multicam enable and bring up multicam window.
5. I edit the multicam sequence and tweak till Im happy.
6. Its all complete, I save and then go to export media.
Whilst exporting the multicam sequence after a few mins I suddendenly get an UNKOWN ERROR message and the export fails?
I think ok maybe I have used some diffent sized footage and try again with the blend footage option in the export dialogue "UNKNOWN ERROR"
Ok problem, I load up CS5 (not CS5.5) I import my CS5.5 multicam project file, it conforms all the footage again and then I go to render out and BINGO it renders out fine?
I go back to CS5.5 to try and find out what is the problem with it and not CS5 and the result is this..
The footage that was in the multicam sequence for the first few mins is whats causing the problem HOWEVER if I go to the original sequence (with all the video streams not the multicam sequence) select and copy all the timeline 1 footage upto the multicam bit, swap to my multcam sequence and paste the single edits at the begining straight over the identical footage in the multicam sequence IT NOW RENDERES OUT without an error.
Please fix this I have to deal with it several times a month and its bloody annoying.
    Mar 10, 2012 7:54 PM   in reply to Hotrod2uk
    You lost me with step 2.
    Mar 11, 2012 4:30 PM   in reply to Hotrod2uk
    I then import all the multicam footage to time lines 2,3,4.
    Now right there is where you're losing me.  The normal procedure is to place all the clips for a multicam edit into just one sequence.  So I'd ask why are you putting them into multiple sequences?
    Mar 11, 2012 4:35 PM   in reply to Jim Simon
    Roddy, I think some of the time you are using the term "timeline" instead of track. Some users call a "sequence" a timeline, but never call a track a timeline.
    Jim, I think he is editing on video track 1, then adding 4 tracks of video in that same sequence for a multicam edit.
    Mar 20, 2012 1:54 PM   in reply to Hotrod2uk
    Well, I can only say that for myself, I'd normally keep only the multicam clips in the multicam sequence, adding the first bit of edit to the second sequence anyway.
    Sooooo, if that works...
