Using LR4 (not the Beta) processing JPEGS in the web gallery module seems to be taking about 5-TIMES as long as in LR 3 (or processing the same set of JPEGS to the same size and quality in Develop module in LR4).
Anyone else getting this problem?
I'm not a software engineer, but I would have thought that processing a large set of images using the same spec would be an excellent opportunity to utilise multi-core processors, and that doesn't seem to be happening on my system:
Mac Pro 2 X 2.66 Ghz - 20GB RAM - OS 10.6.8.
ATI Radeon HD 5870
Canon 5DII RAW files
Colin Thomas
My findings on a test with:
WebGallery export took 87.5 minutes (approx. 5.2 images/minute or 11.5" per image).
I'll run the same test on LR3.6 tomorrow to compare.
Beat
Larry Lilac wrote:
...processing a large set of images using the same spec would be an excellent opportunity to utilise multi-core processors, and that doesn't seem to be happening on my system...
This tends to be a common complaint with all kinds of software. "Why doesn't [fill in the blank] use all of my cores?" The impression is that a "properly-constructed" piece of software ought to be "utilizing every core" for every intensive operation in order to maximize speed.
In reality, it's just not that simple. There are a variety of factors that can influence the usage of multiple cores (or lack thereof) for certain procedures, functions or processing tasks. The complexity that underlies the utilization of multiple cores is just not as simple as people seem to think.
I'm not trying to negate your observations that the LR4 web gallery is slow (personally, I almost never use it). I'm just saying that, unless you are a hardware or software engineer, your better off not trying to draw conclusions about the underlying efficiency of software by monitoring core activity and expecting full-time utilization of every core... there's a lot more to it than the simplified perception that "tasks get divvied up to every core to make things go faster."
I too am having problems with a slow gallery build in Lightroom.
My problem is not limited to v4 but v3.6 as well. I haven't got specific times to compare to what my pc used to do, but anecdotally, these days it is painfully slow to build galleries in Lightroom. I thought it may have been a problem with the plug-in I was using for gallery building but the in-built HTML Gallery (which I haven't used previously) is as slow as the proverbial wet weekend as well.
Hopefull someone has experienced this problem as well and can share a brilliant solution with us.
I noticed all cores being busy during the export.
Beat
- Win7 64-Bit
- Intel i7-980x
- 24GB Memory
- Fast disks
- HTML gallery with 451 images
- Vast majority is CR2's from Canon 5D MkII and 1Ds MkII (approx. 15-25MB each)
- Detail image settings: 70% quality, 1024 px
Beat
I've now run the same export on LR3.6. I don't know if the results really are comparable, as I didn't empty the ACR cache before the second export (so some demosaicing might have taken place in the first export, but not in the second).
The result is that LR3.6 only took about 20 minutes, compared to 87.5 in LR4.0. I also noticed that LR3.6 used less memory per exported image than LR4.0.
Beat
Just exported 89 images into a gallery with 89 thumbnails and various other folders etc as part of a Turning Gate Client Response gallery. The export time was 14 minutes, and I was also using LR4 in develop mode
OSX Lion 10.7.3, MacbookPro 8Gb 2.2 Ghz i7.
I'm not seeing the issue with OSX, but then I'm finding that LR4 is nippy.
I'm exporting from 8bit TIFFs at Canon 5Dii size images, 99% around full frame.
did the same test with the same files and exactly the same web gallery but using LR3.5 - 4 mins.
That is a 3.5 speed increase using LR4.zzz
Here is a bug report link that someone called Tony has set up, feel free to comment on there as well so the Adobe lot can take note.
