sachinprasad
To draw in the pdf using pen tool in acrobat reader x
Mar 5, 2012 5:55 AM
hi im using the app.execMenuItem("Annots:Tool:InkMenuItem"); in the javascript of textbox in acrobat pro 9. When i click the text box pen tool is activated and im able to sign in that textbox.
But in acrobat reader 10.1.2 when i click the textbox its not working . i.e (app.execMenuItem("Annots:Tool:InkMenuItem"); ) is not executing . Is there any other command to get pen tool in acroabat reader x.
    Mar 5, 2012 6:10 AM   in reply to sachinprasad
    Couple of issues there:
    1. Your code should not work at Acrobat Pro 9 at all, unless you've edited the registry and added this menu item to the white-list, or you're actually calling it from a trusted function in a folder-level script.
    2. The menu items in Acrobat and Reader X have changed dramatically. You need to make sure that this item is still available through the menus, and that its name has not changed.
    3. If commenting for the file in Reader is not enabled, its possible that this menu item could not be executed at all there.
    Mar 5, 2012 6:39 AM   in reply to sachinprasad
    Sorry, I'm not following you...
    Mar 5, 2012 7:32 AM   in reply to sachinprasad
    If you're already using the "Execute a menu item" command, why do you need a JavaScript code to do the same?
    Mar 6, 2012 1:30 AM   in reply to sachinprasad
    Execute a Menu Item is not working because these menu items no longer
    exist. Therefore, doing the same with JS code won't work either...
    Mar 6, 2012 2:03 AM   in reply to sachinprasad
    The two are not related. This code adds some annotations to your file. The
    code you want to use needs to select a tool from the GUI.
    It has nothing to do with each other.
  • Thom Parker
    Jul 16, 2003
    Mar 9, 2012 9:33 AM   in reply to sachinprasad
    Yes, there is.  And your code is correct.  If you run that code from the console window you will see that it works.  The problem is that menu item cannot be generally run from a non-privileged context. They have to be on a white list. In windows this is a registry setting:
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Adobe\Adobe Acrobat\8.0\FeatureLockDown\cDefaultExecMenuItems
    On the Mac it's in a setting file.
    Thom Parker
    The source for PDF Scripting Info
    pdfscripting.com
    The Acrobat JavaScript Reference, Use it Early and Often
    Then most important JavaScript Development tool in Acrobat
    The Console Window (Video tutorial)
    The Console Window(article)
  • Thom Parker
    Jul 16, 2003
    Mar 17, 2012 10:01 AM   in reply to sachinprasad
    Sorry it took me a while to get back to this thread, been busy.
    For obvious security reasons a PDF script cannot modify the registry.  Acrobat JavaScript is very well protected.  However, you can save the registry settings out of the registry editor to a ".reg" file.  When the user clicks on this file, Window's knows to import the settings.   In the registry editor, look on the File menu for the "Export" entry.
    Ideally you could make this *.reg file an attachment to a PDF and then use a script to launch it, but I don't think this will work.  There are a number of file extensions that Acrobat will not export. I wouldn't be suprised if *.reg was one of them. So you may have to pass this file around in a zip, or create a windows installer file.
    Mar 30, 2012 7:31 AM   in reply to sachinprasad
    Moving this discussion to the Acrobat JavaScript forum.
