I am working on a batch flattening project using Watched Folder.
I have a parent process for locating the directory and invokes a subprocess for flattening the PDF files.
I want to write the failed directory to the XML.
If there are multiple failed directory locations and if I want to add it to the node, it won't let me do.
If I set the Xpath location as /process_data/outputXML/flattenDirectoryRequestMessage/failureFileLoc ation[x]/@path it gives me invalid character exception.I am using 'x' for looping and incrementing.
If I don't use the [x]. The directory is overwritten.
Any idea how to loop and add all the failed directories to the attribute of the xml node?
I presume that X is a variable of type int.
Just modify the XPATH expression as below and give it a try..
/process_data/outputXML/flattenDirectoryRequestMessage/failureFileLoc ation[x+0]/@path
OR
/process_data/outputXML/flattenDirectoryRequestMessage/failureFileLoc ation[Number(x)]/@path
Nith
Hi Nith,
I tried all this options, Still I get the same error. Anytime I use square parenthesis ([]) I am getting this error. I think may be in Xpath we cannot use the [] to assign values, we can only parse to retreive the values and assign it to another variable in the procees_data. I am not sure tho.
org.w3c.dom.DOMException: INVALID_CHARACTER_ERR: An invalid or illegal XML character is specified.
at org.apache.xerces.dom.CoreDocumentImpl.createElement(Unknown Source)
at com.adobe.workflow.datatype.runtime.impl.xml.XMLDataTypeNode.newEleme nt(XMLDataTypeNode.java:59)
at com.adobe.workflow.dom.InstanceElement.createAndAppendElement(Instanc eElement.java:455)
at com.adobe.workflow.pat.service.PATExecutionContextImpl.createNodesFor XPathExpression(PATExecutionContextImpl.java:899)
at com.adobe.workflow.pat.service.PATExecutionContextImpl.setProcessData Value(PATExecutionContextImpl.java:687)
at com.adobe.workflow.pat.service.PATExecutionContextImpl.setProcessData WithExpression(PATExecutionContextImpl.java:376)
at com.adobe.idp.workflow.dsc.service.SetValueService.execute(SetValueSe rvice.java:54)
at sun.reflect.GeneratedMethodAccessor210.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:600)
at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(Defaul tPOJOInvokerImpl.java:118)
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(Workflow DSCInvoker.java:154)
at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(In vocationInterceptor.java:140)
at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.procee d(RequestInterceptorChainImpl.java:60)
at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.int ercept(DocumentPassivationInterceptor.java:53)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.do InTransaction(TransactionInterceptor.java:74)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapt erBean.execute(EjbTransactionCMTAdapterBean.java:357)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapt erBean.doSupports(EjbTransactionCMTAdapterBean.java:227)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTr ansactionCMTAdapter_caf58c4f.doSupports(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute (EjbTransactionProvider.java:104)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.inte rcept(TransactionInterceptor.java:72)
at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.inte rcept(InvocationStrategyInterceptor.java:55)
at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept( InvalidStateInterceptor.java:37)
at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept (AuthorizationInterceptor.java:188)
at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterc eptor.java:48)
at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineI mpl.java:115)
at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMes sage(AbstractMessageReceiver.java:93)
at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessa geDispatcher.java:225)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(A bstractMessageDispatcher.java:66)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:1 67)
at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:885)
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke (WorkflowDSCInvoker.java:347)
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(Workflow DSCInvoker.java:158)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapt erBean.doRequiresNew(EjbTransactionCMTAdapterBean.java:299)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTr ansactionCMTAdapter_caf58c4f.doRequiresNew(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute (EjbTransactionProvider.java:143)
at com.adobe.idp.jobmanager.execution.workadapter.AbstractExecutableJob. invokeRequest(AbstractExecutableJob.java:127)
at com.adobe.idp.jobmanager.execution.workadapter.PersistentExecutableJo b.execute(PersistentExecutableJob.java:60)
at com.adobe.idp.dsc.workmanager.adapter.UnManagedAsynchronousWorkAdapte r.run(UnManagedAsynchronousWorkAdapter.java:39)
at com.adobe.idp.dsc.workmanager.adapter.websphere.J2WA_Work.run(J2WA_Wo rk.java:34)
at com.ibm.ws.asynchbeans.J2EEContext.run(J2EEContext.java:782)
at com.ibm.ws.asynchbeans.WorkWithExecutionContextImpl.go(WorkWithExecut ionContextImpl.java:222)
at com.ibm.ws.asynchbeans.ABWorkItemImpl.run(ABWorkItemImpl.java:159)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1550)
