Acrobat 7.0.7 does not install/update Acrobat 9 Pro Extended
Participant ,
Mar 12, 2012 Mar 12, 2012
RE: http://forums.adobe.com/thread/911307
The original question was never answered. I have the same problem being an owner of Acrobat 9 Pro Extended. The solution presented only addresses Acrobat X and the E Learning suites.
I cannot use Adobe Presenter due to the Internet Explorer 9 incompatability issue.
JP
Presenter
1.9K
Participant , Mar 12, 2012 Mar 12, 2012
I want to mention that Adobe Presenter 7.0.7 work fine with IE9.
Acrobat 9 might behave bit differently. Please try following steps:-
  • Uninstall Presenter 7.0.6.
  • Download the installer of Presenter 7.0.7 from Adobe website and install in trial mode
  • Go to  (<drive>\Program Files\Adobe\Presenter 7) and go inside AMT folder  Rename AdobeConfig.xml and application.sif files
  • Relaunch Presenter
Presenter installer will sniff the system for a valid Acrobat 9 Pro Extended license and will automatically get
After installing 7.0.7 as a trial, you should be able to run the Presenter intsaller on your Acrobat 9 extended disk and it should apply your serial key.
Participant ,
Sorry if my implied meaning didn't come through in my first post. I tried it and it does not work. Running the Presenter installer on the Acrobat 9 Pro Extended disc merely results in a "Presenter already installed" error. If you were able to get it to work, I'm all ears
JP
Participant ,
Presenter installer will sniff the system for a valid Acrobat 9 Pro Extended license and will automatically get activated
~Shubhi
Participant ,
Mar 19, 2012 Mar 19, 2012
Thank you Shubhi!
This is exactly what I needed to make my work day work!
JP
Help resources
