Can I make the printed document writable?
Feb 28, 2012 11:23 AM
Hi everyone,
Is there a place in RH9 where I can set an option so that I can save the Word file using its original file name? I want to preview the printed document (Word) and make minor adjustments before I make a PDF.
I have gone through the folders and set them all to be writable--although that doesn't seem to matter; they go right back to being read-only!
Thanks in advance,
Mary
    Feb 28, 2012 2:13 PM   in reply to Crone2011
    Are you using source control? If the Word doc has been checked into source control you will need to check it out first. That's the only situation I can think of where a Word doc from RH would be read only, although in that casewither the generation would fail or RH should automatically check it out to start with.
    Amber
    Mar 12, 2012 4:27 AM   in reply to Crone2011
    Mary, I know this may seem like a silly question, but are you generating a Word doc from the Printed Documentation dialog? This option should ideally generate a writable Word document that you can edit, and then convert into a PDF using the Adobe distiller packaged with RH, or using Acrobat if you use that. Just checking
    - Richa
  • RoboColum(n)
    Oct 8, 2004
    Mar 12, 2012 10:47 AM   in reply to Crone2011
    To be honest it is always best to generate the Word file separately first anyway, make any edits and then save it as a PDF.
      @robocolumn
      The RoboColum(n)
      Colum McAndrew
