I've seen the tutorial and the video about this tool where he taps and hold for a second or so to activate the function.... But it does not work... It paints normally and comes back to the same. Can anyone help. Is there a manual coming? Some keys I have no idea what mean.
You are right in saying that the Refine Edge tool does not appear the same as on the tutorial TV. However I tried applying the same technique - outlining the subject without crossing the boundary too much - and it seemed to work. I ended up with a marquee that is tight around the subject.
Hi KingR2,
Refine edge works really well for selecting shapes that have very textured edges (like grass, leaves, hair, or fur). If all you want is to get a soft-edged selection, you should make your selection and then tap the Selection menu and choose Feather. The larger the Radius you use, the softer the selection edge will become.
To really get a good view of your soft edge try this:
Here is a good example of when Refine Edge works most effectively. Compare the edges where the horse's mane and whiskers appear:
I hope this helps,
Luanne
Hi, thank you very much. What I am trying to do is exactly what this example shows. I've managed to use the feather effect which algo gives a kind of transparent shade but helps a lot. The refine edge I still can not use. Do I have to paint around the edge on this function? Thank's for your help.
