hugo2002
How to remove filter or effect  ?
Mar 11, 2012 4:25 PM
I cannot remove effect .
    Mar 12, 2012 1:10 PM   in reply to hugo2002
    Hi hugo2002,
    You can remove an effect by using the Undo button. Here is a picture of where you will find it:
    I like to make a copy of my original before I start using effects. I do this by choosing Duplicate Layer from the Add Layers menu. That way I always have the original image to go back to in case I don't like some of my image experiments.
    I hope this helps,
    Luanne
    Mar 12, 2012 2:24 PM   in reply to hugo2002
    Hugo2002,
    The Effects in Photoshop Touch are permanent once you have saved the file. You will  need to start over with the original file and repeat the cropping task and the add layer task. I'm sorry I don't have a better solution for you.
    Luanne
